Dear All
Looking to use two hole saws with a single arbor to enlarge existing ceiling gyprock holes from 50mm to 70mm something similar to this
Reason to enlarging holes as I can't the downright 50mm with their brackets as I guess there are old style
I have got couple of hole saws set but problem thread on arbor wouldn't fit 2 hole saws
Thx
Evening @zillah
I just popped into the shed at 10 pm and looked through some old hole saw sets.
These are from Clints Warehouse from the early 2000's. Cheap and nasty I admit but would suffice for gyprock.
I can get the combination but the 50mm only protrudes 5mm above the 70mm, so certainly not as long as seen in the photo in your link above.
Another thought is a 50mm wood disc inserted into a PVC pipe section.
Just late night thoughts.
Cheers.
Thx Noyade for your help and appreciate your support
i am thinking about your suggestion 50mm wood disc
And this video exactly what I want to do from 50mm to 70mm
Hello @zillah
It's great that you've received excellent advice from @Noyade. You can also achieve the same effect with the Craftright 16 Piece Holesaw Set. Please note that this is a light to medium duty holesaw kit for wood, plastic and plasterboard.
Please remember to wear personal protection such as gloves, goggles and a mask when using your tools.
There are basically two levels of hole saw sets, entry level and pro.
The DIY one you have has a 'normal' cutting depth.
The PRO sets usually have 'extended' cutting depth, for example used by plumbers and cabinet makers.
I suggest the following workaround (which I have done) providing you can access that area and... it's quite laborious requiring some patience.
Cut to size a piece of plywood to fit between the joists and secure with brackets.
Back inside using a compass find the center of the 50mm plaster hole and boar your 70mm hole.
G'day @zillah
"i am thinking about your suggestion 50mm wood disc"
It does work. I removed the 6 mm drill and replaced it with a 6 mm bolt. Cut the head off and 'notch' the other end for the grub screw.
But it's not pretty.
Cheers.
Morning Noyade
Nice technique
I guess initially you used 50mm holesaw to boar in a thick timber to get 50mm cylindrical template
Then you attached that template to your arbor to be a pilot guide with 70mm holesaw
Hi Mitchel
I have got few around 5 at the house
