Replacing steps and rails on a old Queenslander
OldQld
I’m replacing posts, steps and rails at the back of my home. I will be using a 100mm post bracket that will need to attached to existing concrete. I’m buying a Pryda Post Anchor, the specs say I need 12mm  M12 bolts.  There are so many, I don’t need a bolt and nut or a cup head as I need to drill it into the concrete. Sorry new at renovating. Any assistance would be appreciated.
Re: Replacing steps and rails on a old Queenslander.
Welcome to the Bunnings Workshop community @OldQld. It's amazing that you've joined us, and many thanks for your question.
They would be referring to M12mm Dynabolts, which are used to fix into the concrete. A Ramset 12 x 100mm Galvanised DynaBolt Plus Hex Nut Bolt would be suitable for anchoring down your post supports.
Please let me know if you need further assistance or have questions.
Thank you Mitchell you are a legend!
Hello @OldQld
Just to add to @MitchellMc 's excellent recommendation please don't forget to grab a Kango 12 x 150mm Straight Shank Masonry Bit https://www.bunnings.com.au/kango-12-x-150mm-straight-shank-masonry-bit_p6350317 to drill in to the concrete. Just a reminder to set your drill to hammer function so that you don't burn out the drill bit head. Slow and steady wins the race on this exercise. Good luck and stay safe.
Red
Thank you for the tip Red, appreciate it
