cavity door spanner
chrismack123
Community Newcomer
cavity door spanner
Just jointed.
any idea where to buy a cavity door spanner, not via eBay, need soon. Not on top of door, don’t know size, could be about 10mm
AlanM52
Re: cavity door spanner
Hi @chrismack123
Have a look at this, is that what you are trying to do?
Hi @chrismack123,
Can I trouble you to upload some photos of the door, specifically the track system and the rollers, if there is any way to see them?
I'd say there's a good chance that the cavity door is a Hume Evolution Flush Jamb Door Cavity Unit. This how to install a cavity unit video shows the adjustment spanner being used at 4:40 and the timber pelmet being installed at 5:00.
Looking at the opening with the pelmet removed, it seems like you'd be able to use a standard shifter, but if not, we could certainly look at ordering an adjustment spanner for you.
Step 1, however, is to remove the pelmet. This will need to be done regardless of what spanner is used, so I'd start by looking at how the pelmet is attached.
If you can upload some photos, I could certainly take a look and see what needs to be done to remove it.
Let me know what you find.
