restoring colonial windows
miraperry
Hi all.  Im now up to restoring colonial windows that with badly damaged timber.  Where should i start? What type of putty is best for this situation?
Re: restoring colonial windows
Hi @miraperry,
Thank you for your question.
Can I trouble you to take some close-up photos of what you are looking to restore? The image is too dark to see the details that we'll need to offer our best advice.
Is the damage to the timber? Or are you looking to replace the putty that keeps the glass in place?
Any further details you can provide will help us to answer your question.
I will assist further when you can provide further details.
Thankyou
To answer your questions.  Im looking to restore the windows.  The putty is uneven, cracking and popping out in several spots. Thevtimber is teal bad also.  Do you think sanding will fix timber?
For colonial windows of this age, the putty is usually a linseed-based type @miraperry, which does make DIY work a bit tricky. The inside putty can be patched, but it’s hard to get it perfectly smooth. Most DIY results look similar to what you already have. On the outside, it looks like a lot of the putty has deteriorated and would need to be chipped away carefully. Always wear safety glasses, gloves, long sleeves, trousers, and enclosed shoes when working around glass.
Regarding the timber, from the photos, it looks like the wood has significant decay under the paint. Sanding back will let you see whether there’s any solid timber left, but I suspect much of it is beyond repair. While you might extend the windows’ life a few years by removing loose paint, sanding, repainting, and patching, realistically, the timber may need to be replaced. For serious repair, especially the outside putty and any timber replacement, a glazing or restoration professional is usually the safest option.
Thanks Mitchell for your advice.  Appreciate all the help we can get. have a great day.
