Are Caroma Uniset 2 toilet pans the same size are earlier models?
Merv2
I want to replace an old Caroma 'uniset' toilet pan. Just like to know whether Uniset 2 pans are identical to the older type?
Thanks,
Merv2
Re: Are Caroma Uniset 2 Toilet pans the same size are earlier models?
Welcome to the Bunnings Workshop community @Merv2. It's wonderful to have you join us, and many thanks for your question about toilet pans.
The Uniset II pans are designed for retrofit installations of pans like the Uniset I. They are not identical, as far as I'm aware, as the Uniset II has an updated design. However, it will be the closest to identical you're going to find and should fit in the same space as the predecessor. You might have to re-drill the pan screw fixing holes, but apart from that, installation should be straightforward.
Hi Mitchell.
Thanks for your rapid fire reply, most helpful
Merv.
