What's the best drill bit to drill a 5mm hole into the 15mm-thick side of a vitreous china WC (toilet tank) or toilet tank cover. Once drilled, I'll insert a flexible water tube through the hole to connect the water outlet inside the WC to the bidet using a T adapter (3-way valve.)
Hello @mdashraf5
Welcome to the Bunnings Workshop community. Thank you for joining the discussion. If you've read the previous post it is better to use the 8mm Diamond tile drill bit as it will give you the correct size to pass the hose through. Let me tag @bazzyboy to make sure that they are aware of your question.
Please remember to wear safety gloves, goggles and a dust mask when drilling into a porcelain surface.
The bidet model from the Sydney supplier is called LueLue LB5000 and it comes with the 3-way connector and flexible tubes. Please make sure you chat with the business before they ship it, so that they know the right parts to supply for your specific scenario. I had spoken to a Kevin.
Thank you so much. I've just made an order for it and hopefully can do a same set up as yours 😉
Hello @mdashraf5
Just a friendly reminder to wear safety equipment such as gloves, goggles and a dust mask when drilling into porcelain surfaces. Please remember to drill slowly and use lots of water to prevent heating up the ceramic surface. Please make sure to post an update when you've started your drilling. I'm sure our members will be keen to see the results.
