Can I change to this shower set?
Nanne
Cultivating a Following
Am I able to change the current shower set to Mondella WELS 3 Star 9L/min Matte Black Cadenza Shower Set #I/N: 0238889? IMG_2072.jpegIMG_2073.jpeg
Re: Bathroom shower set
Hi @Nanne ,
That set is designed to be a direct replacement for what you have there, so the chances of it being a straight swap and very good. With wall taps, given they have to pass through varying thicknesses of tiles and wall boards, there can occasionally be slight variations in spindle length. Extensions might be needed on the set if your spindles are especially long.
Please let me know if you have further questions or run into difficulties.
Nanne
What about Mondella WELS 3 Star 9L/min Black Resonance Pin Lever Shower Set I/N: 5004185?
Re: Can I change to this shower set?
As with your other selection, your shower setup is exactly what these sets are designed to replace @Nanne. I had what you currently have and replaced it with a similar kit to those you are looking at without drama.
