Hi Guys,
Do you sell the flexible hoses that go under sinks that have a check valve inside the hose?
To help point you in the right direction, @Lee777, could you please provide a bit more detail on what you are after, such as the hose diameter, whether it is for hot or cold water, and the type of fittings required on each end.
I’m not aware of any standard flexible sink hoses that have an in-built check valve inside the hose itself. If a check valve or backflow prevention is required, this is normally achieved by fitting a separate check valve or backflow prevention device in line, or at the tap or isolation valve, rather than within the hose.
Thanks Mitchell,
What I'm after is flexible hoses that connect from the copper pipe to the tap that have an inbuilt check valve that holds the flow of water in the event of the hose bursting.
Do you stock these products?
Thanks for clarifying, @Lee777. It sounds like you might be after something like the BOSTON 450mm Burst Guard Plus Lead-Free Water Connector. If the hose bursts, it has a shutoff valve within the hose to stops the flow of water.
