How to add a tall corner cabinet across walls?
ELI5
Cultivating a Following
How do I add a tall corner cabinet across both walls here? Any suggestions on available products that could be used would be helpful as well. Thanks.
Re: How to add a tall corner cabinet across walls
Hello @ELI5
Were you thinking of a cabinet at a 45degree angle or just an ordinary pantry height cabinet such as the Flatpax 450mm Utility 1 Door Tall Cupboard. If you are after a very large cabinet the next size up is 600mm wide, then followed by the 900mm cabinet pantry. If you can provide us with more information in regards to what size you prefer, we'll be more than happy to make recommendations.
ELI5
Hello @ELI5
I suggest looking at this unit Bedford 900mm White 2 Door High Moisture Resistant Split Slimline Cabinet as it is close to the measurements you've indicated. I also recommend visiting your local store to see the other cabinets in stock that might fit your allotted space.
ELI5
Thanks, just to clarify, it's one with a 45 degree angle. The suggested ones aren't if I am not mistaken
Hi @ELI5
If you are looking at the Kaboodle Corner Kitchen Pantry, I recommend double checking the space you have as both sides are 1000mm long. Another possible cabinet is the Flexi Storage Wardrobe White Matte 6 Shelf Corner Unit, but this also has a 970mm wall length. Otherwise, you might need to build it from scratch.
