How to add laundry benchtop in a rental?
sareh
Cultivating a Following
I am in a rental so limited to what I can do. I have a small laundry and wanted to add a bench too. Is there anyway that I can fit a bench top without drilling. I am sure that if I get a bench top and sit it on top of the washing machine it will probably slide down the broom cabinet side. How can I make this a bit more functional bearing in mind it is a rental and would want to dismantle it once leaving the property.
Re: How to add laundry benchtop in a rental?
Hi @amelia2,
That sounds like a perfect solution that I wish I had thought of. Thanks for sharing.
I'm looking forward to seeing the finished product.
amelia2
Hi @JacobZ,
well I managed to finish the bench and sink cover (minus oiling as that will take a couple days). Absolutely love it 😊 BeforeBeforeMaking the bench over the washing machineMaking the bench over the washing machineBench finishedBench finishedMaking the slide out sink coverMaking the slide out sink coverSink cover finishedSink cover finishedWhole project + my doggoWhole project + my doggo
Afternoon @amelia2
Nice solution and a bunch more space to play with! :smile:
Great work @amelia2!
I can't wait to see it once you've finished up oiling.
sareh
Amelia,
I really like this idea.  I may have to put a laundry sink cover on now also.  Was that just a slab to sit on top that can be easily removed?
Hi @sareh,
Allow me to tag @amelia2 so they are notified of your question.
Hopefully she will respond soon.
amelia2
Hi @sareh
yes it’s just a slab that sits on top of the sink and slides off. I just measured the sink then measured where the taps were and used a hole saw and jigsaw to make cutouts for the tap and washing machine hose. Then place on top of the sink and slide it in
Hi @amelia2 ,
Just wondering, where did you buy your pull-out drawer?
Thanks!
amelia2
Hi @bhetz2000
I found the pull out drawer at an op shop but I believe it originally came from ikea. Not sure if they still sell it but hope that helps
Hello @bhetz2000
I suggest having a look at this guide - How to build a slimline spice rack. If you are handy with the tools, you can use this guide to give you ideas on how to recreate the pull-out drawer cabinet. The best part is that you can modify it to your hearts content and have it at any size you need it to be.
