How to connect washing machine drainage house?
Just_Mum
I have just purchased a new washing machine and the drainage hose doesn't have a rubber end for me to connect to the spigot on the sink waste pipe. Can I purchase a rubber end for it. The guy who installed it said I needed a whole new hose.
Re: Washing machine drainage house
Hi @Just_Mum,
Can you check the diameter of your hose and the spigot?
I am relatively confident that one of these Nylex 34mm Reducing Joiners would work, but I want to double-check that the diameters are correct.
Assuming your grey water hose is 34mm, and the spigot is around 22mm, it should work.
Let me know what you think.
Is the measurement based on the external diameter or internal. I currently have the following outlet cap on the spigot which is watertight.
https://www.bunnings.com.au/deks-pvc-trap-dishwasher-outlet-cap_p0136005
I have since found the couplings for the old machine that was connected, so I think I'll take them up to my local and see what I can find.
External diameters @Just_Mum,
Taking a hose with you in-store is a great approach. Hopefully, a plumbing team member can find suitable fittings.
