How to fix bathroom vanity plumbing?
husainZahid
I have replaced my existing bathroom vanity with a new one and need some feedback & suggestions for the waste/drain plumbing.
I know I should have hired a licensed plumber to do this, but I am on a budget here. I need some feedback on the plumbing and know if what I have done is satisfactory or does it need any improvement.
The connection/joint between the trap and PVC pipe does not look correct to me. It seems there is some size difference or I need to use some sort of adapter for this joint. I have tested the fitting for water leaks by manually pouring water in the basin and confirmed there is no leak.
So far all plumbing is draft and I have not yet glued any joints so I have the option of redoing the joints if I need to.
I have also included a photo from the old vanity showing the previous plumbing work.
Thank you in advance for your time.
Re: Bathroom vanity plumbing
I’m afraid I can’t provide plumbing advice on whether your installation is fully correct or compliant @husainZahid. It’s not just a legal matter, it’s a safety and compliance issue, and plumbing work really does require a licensed plumber to verify and complete.
From the photos you’ve shared, I can say that the connection you’ve made looks like a standard compression fitting going into a short length of PVC that then meets the bend, which suggests the sizes are compatible. I don’t personally see any immediate issues with it, and it held water when you tested it.
That said, I can’t confirm that this is fully correct or compliant, and the safest course is to have a licensed plumber review or make the connections. I’m sorry I can’t provide more specific guidance here, but it’s really the only way to be sure your installation is safe and up to code.
Thank you @MitchellMc for the feedback and suggestion on engaging a licensed plumber.
