1) Flush Valve
2) Back of the Flush buttons
3) Seating Washer
Good afternoon, friends from Bunnings Warehouse!
My toilet has a leak from the cistern to the toilet, which I believe can be solved by replacing the seating washer.
However, I do not know exactly what brand and model to buy. The brand of my flush valve seems to be WDI, however, I could not find any seating washer of this brand on the Bunnings website.
Picture #1 shows my flush valve.
Picture #2 shows the back of the discharge buttons, where it is written "WDI K4020".
Picture #3 shows, in close, the seating washer where it shows a code: "R07".
An important piece of information, which I find important to register, is the measures of seating washer:
- External diameter: ≈6.5mm
- Internal diameter: ≈3.5mm
- Thickness: ≈0.3mm
As I mentioned earlier, I found several brands/models on the Bunnings website, but I'm not sure which one(s) could replace the one I have.
Perhaps, some of you could tell me which seating washer could properly fit my flush valve model (even if it's a generic brand).
Thank you all,
Mateus.
I was definitely thinking this too. Cheers!
I managed to fix my leaking toilet cistern issue after multiple attempts. I had the exact same toilet flush valve as described above.
1. The name of the model is Parisi WDI K4020. I tried to replace the rubber plug of my existing toilet flush Parisi WDI K4020 with the Kinetic 65mm Geberit Washer from Bunnings as recommended above.
https://www.bunnings.com.au/kinetic-65mm-geberit-washer_p4920267
However, the water leak continued despite replacing the rubber part. Actually water leak was worse after the replacement.
2. I decided to replace the toilet flush valve completely. I managed to find the exact same toilet flush valve as my existing one. There is only 1 shop in Australia which sells this part. I drove to their shop in Mascot to grab this product.
I changed the toilet flush valve but micro water leak continued despite of the replacement.
3. I applied some silicon gel around the rubber part of the toilet flush valve. Only smear. Then water leak stopped completely.
Hope you find my advice helpful.
Hi @hjhch1234,
Thank you for taking the time to jump on and document your experience for others to follow along. It is people like you who make this community a fantastic resource for others, and we greatly appreciate it.
