How do I remove the drawers on the estilo 750mm vanity unit.
Hi @hprider
First you need to open the draws and you should find two black levers on each side of the draw inside the slide rail stand each side of the draws and on the left hand side push the little lever down and on the right side lift it up pulling draw gently outwards.
On some models there mabye a lever lock located in an opening 30mm past the levers deeper into the draw aslo inside the sliding channel you need to depress before operating the levers.
If these instructions dont work try other combinations of lever release upwards and or downwards appling gentle force to draw outwards you should feel it slide forward a bit once released.
See how you go. ![]()
Hi @hprider
Found this youtube video which may help you more they take screws out ? I dont think that is necessary, try the levers first.
Welcome to the Bunnings Workshop community @hprider. It's wonderful to have you join us, and many thanks for your question about removing drawers.
Since Estilo is closed during the holiday break, let's try to solve the issue now. Please push the bottom draw in and then take a picture underneath the top drawer showing the drawer slides and any mechanisms. As @Jewelleryrescue mentioned, there's likely a mechanism to depress that will allow you to remove the drawer. Also, try the old-fashioned method of fully pulling the drawer out, lifting the front at an angle, and continuing to pull it out.
Thank you for your reply.
I have tried lifting the drawer on an angle but this was not successful.
I have taken photos of the rails but it is a very tight space and cannot be seen without a camera.
Unfortunately the video of the floating Estilo unit is not applicable to the runners on this unit.
I had a plumber here yesterday who was also unsuccessful in trying to remove this drawer.
I am wondering if I will need to dismantle the drawer.
What about the front of the runner from underneath @hprider? Your last image shows the back of the runner, but typically, there would be a button or lug that needs to be pushed in at the front of the runner to allow the drawer to run off the end of the slider.
I have see mechanisms where the front of the drawer needs to be removed to access it.
Hi Mitchell,
There are no visible levers or ones that I can feel at front of the runner.
Please see photos.
Hi @hprider Both myself and @MitchellMc are expecting to find a release mechanisim for those draws somewhere yet it is defying the normal draw sets functions.
The last straw method is to pull draw out looking for peep holes through the slider and undo the screws mounting the metal slider to the draw timber itself, . To reinstall is the reverse of this. But with drawer closeto wall the wall side screw hard to access.
Sorry this is turning into a bafffing mystery where it should be easy.
Dear Jewellery rescue and Mitchell,
Thank you both for your help and suggestions. I will look into accessing the screw mounts.
I need to access the breach for the taps so removing the vanity top is my next option but not my favourite option.
Best wishes,
Heather
There don't appear to be any obvious mechanisms to release the drawer from the runners @hprider. I'd suggest the next move might be to remove the drawer front to see if that reveals any hidden mechanisms.
