When I open the skylight with the handle it slips out of place. Looking at it, it seems there is space for a “pin” of sorts to keep the clasp in place. Where I have drawn the orange line. Can anyone point me in the direction of where I would find this? Thanks
Hi @obepum,
Does it look like it's missing something like a hinge pin?
If so, could you give us a rough diameter of the opening?
You may be able to just put something like a Connector Bolt or a small piece of Steel Rod through to allow for regular operation.
Allow me to tag @Noyade, @Nailbag and @AlanM52 to see what they think.
Hi @obepum
The window connector has a steel ball within each side that rolls and grabs the centre tongue of the articulated wider arm. I suspect due to age that one or both balls are either seized or in need of adjustment.
Start with a light spray of WD40 into each side then wipe clean the excess. Then there is hopefully a flat bladed screwdriver adjustment on the outer sides to adjust the ball tension.
Wind each side in very slightly to increase the grab tension.
Howdy @obepum,
That is not the usual winder to window connection.
Here is regular (Whitco) window winder that I used to make a pocket hole jig.
Most of those winders usually connect to the window via a hinged brass plate with slotted screw holes.
Simply back off the countersunk screws and lift up to disconnect.
I am pretty sure your winder uses a spring loaded double ball catch.
Check the tension adjustment screws they will likely need to be wound in a bit more.
I have a box of those, my preferred cabinet door catch.
