Repair cracked shower base
stasiagarraway
Hi there,
I am attempting a cosmetic makeover on my tired 30 year old bathroom.
My shower pan has a rather large and deep crack in it that I’d like to repair. The shower floor is a little spongy around the crack, but will be filled with expanding foam to secure it.
1. What is the best and easiest way to repair the crack and drill holes from the filler, that will allow me to paint over them?
2. What paint should I use to paint the shower base once it is repaired?
Re: Repair cracked shower base
Welcome to the Bunnings Workshop community @stasiagarraway. It's amazing to have you join us, and many thanks for your question on repairing shower bases.
It sounds like our helpful members will need to see some images of the damage you're trying to fix to offer a solution. A cracked shower pan and spongy floor do not sound great, and I suspect this is something that expanding won't fix on its own. Before repairing the damage, my first concern is the integrity of your waterproofing membrane/shower pan. A spongy floor would indicate significant damage to the underlying structure and could suggest a breached waterproofing membrane/shower pan.
From what you have described, this sounds like an extensive repair is needed. The tiles and shower pan will need to be removed, any damage to the floors structure assessed and repaired, waterproofing membrane re-applied/shower pan replaced, and tiling redone.
I look forward to seeing some images of the damage and offering some suggestions for repairing the area.
