How to replace rusted bathroom door hinges?
alexreed092
Hi I need to replace these rusty bathroom door hinges and have two questions:
-What's the best way to remove them/what tools do I need?
-What sort of door hinges are best to replace them with?
The width is 2.5 and height is 3.5cm. Thanks in advance!
Re: Replace rusted bathroom door hinges
Hello @alexreed092
Thank you for sharing your question about your bathroom door hinges. Your hinges are fixed in place using blind rivets. To remove them you'll need to drill the center section out and install new ones in. As for the hinges, I suggest bringing them to the store and finding similar ones in size. If you can find a stainless steel one in the same size that would be ideal. I propose using
Here is a handy guide that will help:  How to use a Hand Riveter
