Full Boar pedestal drill on clearance
Noyade
I'm not sure if every Bunnings store is the same - but mine now has on clearance the Full Boar pedestal drill.
Current price is $224 - this is around $70 less than the smaller Ryobi bench-top drill press in store.
I think this is a remarkable buy - and considering a 750 watt motor.
Just a heads-up.
Cheers!
AlanM52
Re: Full Boar pedestal drill on clearance
G'day mate,
Yeah that's a good buy and these days I usually look but don't buy because I've past that age point (78 next month) where I need to curtail new purchases or upgrades. Having said that I recently purchased this Ozito Plunge Saw  😃
Tip: Wait for the missus to be somewhere else then transfer from vehicle to workshop 😎
Drill press bench.
Noyade
G'day Alan.
"Yeah that's a good buy"
Yes, I believe so. I don't know Bunning's clearance pricing procedure - but I suspect that price will get even lower if the stock does not sell.
I was there the other day and none were sold since I made the opening post above - but if you continue to wait, with my luck a bus load of pedestal drill seekers will turn up and buy the lot in one go. 😁
Nice plunge saw Alan - any project thoughts?
"I need to curtail new purchases or upgrades."
I was feeling the same way until recently. Life is short and I would like to try/buy a few things and upgrade for the sheer fun and enjoyment of it.
Budget permitting.
The recent table-saw purchase has been absolutely fabulous. Did I 'really' need it? Probably not - but it has been a wonderful experience considering what I have been using.
Cheers!
Noyade
Hello @Noyade.
"but I suspect that price will get even lower if the stock does not sell."
They're now down to $150.25c.
Noyade
Well, the price didn't drop any lower.
So I bought the second last box - this was late last year.
I only set it up today. First issue - it wouldn't turn on. Then I discovered the belt lid has a latch mechanism that engages a switch so when the lid is closed - the circuit opens.
Problem is there is an anchoring bolt (M6) which I suspect was over-tightened in China and shattered the plastic mount on the switch box - so the box is floating free.
I tried double-sided tape to 'engage' the lid bracket.
And away she went!
Then I discovered - a much minor issue - the light doesn't work.
I thought I could try a household Edison LED light - but then discovered it's 12V DC - ?
With a mirror - I think I can just make out the transformer?
Where/how would you find a replacement?
Is there a way with a multi-meter I could check the problem is the bulb?
Cheers!
AlanM52
Howdy Noyade,
RE: Is there a way with a multi-meter I could check the problem is the bulb?
Yep...
Click Hobbyist Multimeter.
Buy that, you can get one regardless of where you live on this planet.
Sitting in front of the Desktop PC I just reached over and grabbed one of those off a shelf.
The all (more or less) come out of the same factory, the Click one heading for Bunnings and the Digitech to Jaycar.
Let me come back tomorrow and we'll run through how to test that LED globe with that Multimeter and when you have one you can do the same again for practice.
RE: Where/how would you find a replacement?
I searched Bunnings for a E27 G45 LED bulb but as expected could locate one.
The workshop team may find something or redirect you to Special Orders and if you can also get a spare.
Chat tomorrow...
Noyade
"Chat tomorrow..."
Looking forward to it @AlanM52 !
I have a few multimeters mate - even one from when Dick Smith started. But I do like analogue - watching that arm swing back and forth...
I even have my 1978 General Electric calculator ready for the hard equations (does anybody buy calculators these days?).
I did try resistance and continuity - but thought that would only apply to incandescent bulbs?
Cheers for now.
PS - at the end of the day it's all rather moot. I believe the 'light' would be rather useless at 2 watts - and it's behind the chuck. But the problem solving is the fun part. 😁
AlanM52
You need a meter with a diode test function.
Set the multimeter dial to the diode symbol.
Touch the probes to the globe terminals. If it does not light, swap the probes to test polarity and if still no light globe is dead.
I think your best bet is Special Orders desk for replacement.
 I use the LED work light spring clamp type with goose neck.
Noyade
Diode?
I didn't see that coming.
I'll sift though a few other multimeters and get back to you.
Cheers.
Noyade
OK - looks like Dick Smith is comparable to your machine.
"If it does not light,"
Not sure what you mean by this @AlanM52 . There is no light - no numerical change - just "1" visible.
This is for the Full Boar bulb.
And every other LED (240V) that I know to be working.
