How to build a shed extension?
rick6947
Hello Everyone,
I am building a shed in my carport making the walls out of wood (Treated timber on the base) what is the best product to use for the external walls is plywood good to use something like Ply Panelwood Grooved 9mm? Open to other alternatives. This shed will be an extension of my current shed i have.
Regards
Rick
Jewelleryrescue
Re: How to build a shed extension?
Hi @rick6947
Ply I would use as a  last resort as even if  painted will not last as long as other products.
I would use sheets of colorbond  fencing panel low  cost at around  $30  just screw them to the frame ( make sure there is some middle  framing timber to support it in a wind storm or there are roofing panels of  plastic  and  galvanised steel.  Gal roofing tends to be of thicker metal than wall materials  so costs a little more but  you may reap the longer life rewards for your project.
Also there is a whole range of Textured cement cladding
You could go old school timber weather board. Or  modern  aluminium  material  equivalence.
If  this is a feature   add on spend more on its looks as a guide.
Search in  Bunnings  for external wall cladding see what draws  you attention.
Re: Shed Build Question
Hi @rick6947,
Thank you for your question about choosing a cladding for your shed.
Plywood is not typically used as external cladding as it is not as weather-resistant as alternatives.
Fibre cement cladding systems such as Hardie Groove or Hardie Oblique Cladding are great options. They are usually part of a system that includes accessories like these Aluminium External Trim Corners to minimise the risk of water ingress.
Weatherboards, both timber and fibre cement are also good options.
As @Jewelleryrescue has said, corrugated metal sheeting such as Colourbond is also a good option.
