Hi all, I am about to build a small wooden garden storage shed (3m wide x 2.4m deep) on a gravel base. I have been soaking up tutorials, reading the various excellent posts on this forum and on wooden framing and feel fairly confident about most stages but there are a few grey areas that I would love the community guidance on (and will likely lean on you for tips along the way!).
I previously prepped the ground and laid a gravel pad. The plan is to put 2 x 6 treated joists directly into TuffBlocks as the base of the shed and build on top of that.
So my questions are:
Flooring
1. I am looking at treated yellow tongue STRUCAflor is this suitable or is there a better alternative? Treated plywood looks very expensive but I don't mind paying if it means increased longevity.
2. Silly question, but given the fact an exposed tongue in these boards will be at one edge of the shed. Do you just cut these off or just fill the gap with sealant?
Walls
1. What options do I have for external wooden wall panels? I would like something that looks nicer than particleboard or OSB. Is there an outdoor option of these slotted panels? I guess I could use weatherboards but curious at alternatives.
2. Should I use building wrap?
Roofing
1. What are my options here? Just colourbond sheets? If yes, should I still put a plywood/OSB roof on and apply the colourbond to that or just attach it straight to the rafters? I assume I would have lots of gaps if I attach directly to the rafters.
2. If colourbond is the way to go, I'm curious to know what you use so that you don't just have sharp raw edges and what to use for the apex of a pitched roof?
Fasteners
I'm going to use screws instead of nails for framing (Personal preference, if I had a nailgun it might be different 😄). So I don't want to have to pre-drill or anything. What gauge is best, 12g? or thicker? Something like these Buildex RapidDrive Treated Pine Screws 12g x 75mm?
I think that's all I need to know at the moment, once I have these answers I can make my materials order and get stuck in!
Thanks so much
Thanks @MitchellMc that tread looks good also.
@Dave-1 Ha ok, I'll do eves 😅 where do you attach soffits? To the rafters on a diagonal? I have those fascia boards with the indentation at the top and bottom for (I assume) soffits but then:
A. What do I attach them to?
B. There is a huge void left as the soffit is so low down, or is that ok?
See here
Afternoon @mikebarker
Id attach to the rafters, I do know of the slots on the facia but not sure what theyare for. The way I figure it is the facia boards are what the gutters are attached to so factor that in when putting the tin sheet on the roof (I didnt when I built my deck and kinda nervous about when I do)
Also the second photo woul mean you need to install another piece of timber on the wall to support that side of the facia board.
Howdy chaps! I hope your weekend is going well. The shed build is going really well, mildly slowed by some cladding indecision on my part but I've decided to go with full Colorbond (Cladding and roofing).
Given the material choice for cladding I have questions about preventing water ingress in the window and the door. Purely due to the corrugated nature of colorbond. Using the top of the window as an example, assuming I put some flashing around the window cavity, I assume there is then just gaps where the corrugation dips? I know I'll be using the foam inserts for the roof gaps but is that also applicable here? And with the door, unless I use colorbond on the door exterior and match up the corrugation to the external walls, water will easily get in.
I'm sure this is a problem that has already been solved but I am clueless!
So, adjacent to my water concerns, to give my door some coverage, I am now considering adding eves to the roof above the door. But I've already partially completed the rafters - without the extension component for the eves. I opted for thinner 90 x 35mm timber, so my question is, with a small overhang (I was thinking approx 400-500mm) can I stick with this thinner timber or do I need to replace my rafters with 90 x 45mm? There will be the weight of the colorbond and the fascia boards. It would be great to be able to keep what I have and just replace the rafters with longer pieces, and not the blocking that sits in between the rafters but I'll do it if needed.
Thanks!
Like your idea I have never thought of how to fit a window or a door to a corrogated wall before. First thought was maybe check out some sheds around the place or pics of sheds online and backwards figure out how to?
Second thought was what requirements are def needed, A Window sill with a bit of a slope, and maybe a top window with a bit of a slope? the sides can be covered in trim. For the door the same idea, A sill with a slope and a cap to it so the water if it gets on the tin runs down and is naturally funneled to the edge of the timber.
For the extension, you could add legth to a few of your trusses by bolting/screwing long lengths to the existing rafters side by side with the extended bit for the overhang? That way the strength you have is still there if not added to making it more solid.
