How to build weatherboard cladding battens?
Hi folks,
I'm planning on a small project to build an extension 10m2.
Attached is a draft frame drawing (unfinished).
There are 3 walls need to be cladded with weatherboard.
Can you please give me some advice on?
1. Between James Hardie Primeline Newport vs Weathertex Primelok Federation Smooth, which one is more reliable?
2. Do I need to use battens between frame stubs and weatherboard? People recommend battens system to ensure airflow and avoid condensation.
Thank you so much.
framing
Re: How to build weatherboard cladding battens?
Hi @tan_tran81,
Welcome to the Bunnings Workshop community. We're pleased to have you join us and look forward to reading all about your projects and plans for around the house and garden.
Please note that there might be a delay in getting back to you as one of our resident Bunnings D.I.Y. experts is on leave today.
Thanks for your patience in the meantime,
Hi @tan_tran81,
When considering materials, James Hardie Primeline Newport is known for its durability and resistance to moisture, rot, and termites due to its fibre cement composition, making it a reliable choice for longevity and low maintenance. On the other hand, Weathertex Primelok Federation Smooth offers a more natural look, being made from timber products; however, it may require more upkeep to prevent warping or cracking over time. If longevity with minimal maintenance is your priority, Primeline is likely the better option, while Weathertex can be suitable if you're willing to invest in regular care.
Using battens between the frame studs and the weatherboard is highly recommended for several reasons. Battens create a cavity that promotes airflow behind the cladding, helping to prevent moisture buildup and reducing the risk of mould and rot. Additionally, this system effectively manages condensation by allowing moisture to evaporate rather than getting trapped against the building materials.
Here's the installation guide for Primeline and Weathertex.
Hi Mitchell,
Thank you so much for the comment.
Tan
Hi @tan_tran81
I've installed both systems mainly with replacement boards and personally I have found the Hardy product the easiest to install. And as @MitchellMc mentioned the Weathertex product though looks more natural, but have been the more common boards I have had to replace due to poor maintenance. And definitely follow his advice on the battens to reduce the chance of internal cavity moisture.
What screws for external stud wall build?
Hi Folks,
Can you please recommend screw size to build external stud wall framing size 90mm x 45mm?
There is mixed of toenail and straight screwing.
Thank you so much.
Tan
Re: Stud wall screw size
Hello @tan_tran81
Thanks for sharing your question about what screw to use on 90x45 timber. I recommend using either Zenith 10 - 8 x 75mm Galvanised Countersunk Rib Head Timber Screws or the Buildex RapidDrive Treated Pine Screws 10g x 75 mm (10 TPI) Climacoat. Please remember to drill pilot holes to prevent the timber from splitting.
Here is a link to a handy guide: How to choose the right screw for the job by @Adam_W.
What timber to use for batten between frames and cladding?
Hi Folk,
Can you please recommend product for battens between frames and cladding?
These battens is for air flow and prevent condensation.
Thank you so much.
Re: Recommend wood type for batten
Hello @tan_tran81
Thanks for sharing your question about what wood type to use for battens. Generally, I would suggest using 70 x 35mm Framing MGP10 H2 Blue Pine 2.4m for inside the house. Can you please tell us more about what you are trying to build. Is it a wall or are you framing over an existing brick wall? Is there a specific size you are after? What kind of cladding are your using? Any extra information can provide would be every much appreciated.
Subject | Author | Posted | |
March | |||
October 2023 | |||
February 2024 | |||
October 2022 | |||
April 2023 |
