How to make a saw-table?
VulcanJohn
Building a Reputation
Hi everyone, when I need to cut long pieces of wood or boards, I find my circular saw awkward to keep straight, especially when I have to start leaning across the workpiece to get to the far side. I don't have a proper workbench, just an old Black & Decker workmate stand that I can clamp the pieces to. Now, If I could find  way to mount my circular saw under the workbench, so I could feed the work through it, I think that might be a solution. Yes, I could go and buy a table saw, but storage space is at a premium and I'm not sure I would use it enough to justify the cost. Any thoughts would be welcome.
Re: How to make a saw-table?
Hi @Noyade
I wonder how accurate this table saw is? My only other concern is the safety aspect of the saw itself. A few timber screws holding the saw does not fill me with confidence.
Brad
Kind of a Big Deal
I think I will stick to my Bosch GTS 10 XC.
Unless someone wants to buy me a MiniMax CU410 Elite Combination Machine.s-l1600
Noyade
Kind of a Big Deal
Hi @Brad
"Belt driven with a washing machine motor."
And I'm sure it worked a treat. My father's hybrid table saw is powered by a floor polisher motor - 1 1/2 HP.
Noyade
Kind of a Big Deal
Not sure if this is a washing machine motor?
But he made a disc sander outta a spare motor from somewhere.
Used a belt pulley to mount the face.
Brad
Kind of a Big Deal
Given the ease that the motor stalls I think it may be 1hp or less.
Used a linkage belt.
VulcanJohn
Some of these home-built contraptions are wondrous bits of ingenuity and lateral thinking, but somewhat scary in these OHS days. However, like many things, they were "of their time" and served a purpose without too many fingers being lost. You would have to hope that anyone clever enough to think of the design, and then build it, would have the common-sense to know how to use it safely!
My search for a machine for the current time has brought me back to the $699 Makita unit. (Bunnings i/n 0118523). I had a chance to get my hands on one and it seems to hit the sweet spot for price, build quality and being a well-known brand. Now I just have to start saving my pennies, and clearing a suitable space in the garage. Thanks to everyone for your information, ideas and stories about table-saws.
Happy building.
John.
It's great to hear you managed to get your hands on the Makita and found it suitable @VulcanJohn. What convinced you that it was the most suitable machine? Less play in the guides?
I'll be looking forward to hearing your review on it.
MikeTNZ
Amassing an Audience
Hi @VulcanJohn,
I bought one of the cutting guides from Bunnings a couple of years ago, for the very reason you're describing.
Best thing I ever bought, once you know the offset from the edge of your saw blade to the edge of the base-plate, it's too easy to make good,
straight cuts every time.
Sorry to go off topic here, but I was watching a YouTube video by a guy in the US and he was using some type of solid foam sheet insulation as a base for his timber and having the saw blade cut into it with the whole setup on his workshop floor.
Has anyone here heard of a brand name for this material and if it can be sourced down-under?
Cheers,
Mike T.
Noyade
Kind of a Big Deal
Hi @MitchellMc
I watched a fence contracting team trim the bottom of a newly installed picket fence the other day. They were using a Festool plunge saw and rail system.
Very impressive. They must be able to connect the rail as it was a 10 metre length? Wanted to ask, but they looked busy.
Does Ozitio still make a plunge saw? I only see the rail...
The kit still appears on the Ozito website @Noyade, so we should be able to order it in. They might be changing the model hence it not appearing on the webpage. I can't imagine it's going anywhere as plunge saws are becoming more popular with D.I.Y. enthusiasts. I was using a Makita plunge saw a few weeks back and was very impressed.
