How to convert shed to semi-habitable space?
CaptKip
I am looking to extend and build a semi habital space in the carport area of this shed. It is roughly 3m x 8m and about 3.6m on the side of the shed up to 4.2m to the apex.
There is no slab in the area we want to build. So I’m hoping to do the slab myself and build the walls and just clad the outside with the same steel used already. I have some building experience but not a lot. We don’t have a lot of $ so going with second hand glazing. I have an idea of the layout and will share that soon. But I guess I wanted to ask how much you think something like this would cost? The Main reason for going this route is to get ourselves on the land to live in the shed then look to build our main house after. I’m just tracking the journey so if anyone else can guide me or needs some direction this thread will be available. I look forward to the journey, it’s not my first rodeo but I know it’s a big task. But I’m determined and keen to get it happening. Appreciate any and all advice.
Capt Kip
CaptKip
Re: Shed Conversion
Re: Shed Conversion
AlanM52
Amassing an Audience
Re: Shed Conversion
Hi @CaptKip,
Trying to see a bigger picture, the only structure on the block is a carport with boat storage - yes.
Cheers
Re: Shed Conversion
Hello @CaptKip
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about converting your shed.
It is an exciting project to be undertaking but will involve a lot check and balances in regards to construction. Because you are building a habitable structure, you'll need quite a number of permits before you can begin. I suggest visiting your local council and having a look at their list of requirements in regards to what you'll need to provide before you begin your project. I also recommend engaging the services of a draftsperson or engineer to provide you with the necessary plans to submit to the council. This would also be a good opportunity to discuss the location of the utilities along with kitchen and toilet locations.
