What Ryobi products and batteries are compatible?
otnimus
I am planning to get a cordless Ryobi lawn mower: https://www.bunnings.com.au/ryobi-lithium-36v-5-0ah-18-brushless-lawn-mower-kit_p0088131
And I also need a drill and looking at this one: https://www.bunnings.com.au/ryobi-18v-one-drill-driver-skin-only_p0096074 which is a skin only. How do I know if I can use the mower's battery for this drill? And in general how do I tell which Ryobi products will share batteries? Thanks.
Re: I need a new battery for my Ryobi 36v Chainsaw
Welcome to the Bunnings Workshop community @003chris
I'll reach out via private message for some additional details and see if I can assist in any way.
Derek5
compatibility
is the OLP18 bypass lopping attachment compatible with the R18PHT130 pole hedge cutter
Re: compatibility
Hello @Derek5
Welcome to the Bunnings Workshop community. it's sensational to have you join us, and thanks for sharing your question about Ryobi compatibility.
The18V ONE+ 32mm Telescopic Pole Lopper Attachment is part of the EZ Reach range and will work with the Ryobi 18V ONE+ 40cm EZ REACH Pole Hedge Trimmer R18PHT130.
BillT
Ryobi lawnmower battery
My Ryobi lawnmower RLM36BL purchased in 2023 stopped today soon after I started mowing, despite starting with a fully charged battery (4ah36V Lithium).  When I removed the battery and checked the charge indicator it showed only one light, but when I put it back into the charger and switched it on, the charge indicator showed all four green lights.    I took it off the charger and again it showed only one flashing green light, and would not start the mower.
Is the battery stuffed?
Re: Ryobi lawnmower battery
Welcome to the Bunnings Workshop community @BillT. It's fantastic to have you join us, and many thanks for your question about Ryobi batteries.
It definitely sounds like there’s an issue, though it’s hard to tell from your description whether it’s the battery or the charger causing it. If you have another Ryobi tool that uses the same battery, or another battery for the mower, you could try swapping them to see whether the problem is with the battery or the charger.
From what you’ve described, it’s more likely that the battery itself is at fault. Ryobi 36V batteries usually come with a three-year warranty, so since yours was purchased in 2023, it should still be covered. I’d recommend taking the battery, the charger, the mower (if purchased as a bundle), and your proof of purchase to your local Bunnings store and having them assess it under warranty. They should be able to swap the battery out if it’s faulty.
Medsy
Ryobi 18v batteries compatibility
I bought replacement 8ah HP ryobi 18v batteries for my ryobi lawn mower only to find they dont fit the law mower.  the mower is only 2 years old.  Are there now more than one, one+ ie actually two+?  Why are they still be advertised as universal?  Can I get a new mower as I have been sold a bit of a fib?  I have found that in store nobody really knows.
Regards
Bill
Re: How do I know which Ryobi products can share battery pack
Hi Mitchel, this is not correct is it.  There are three!  18V one+ ,  18Vone+ HP and 36V.  Many devices, over 25 of them, cant use the 18V HP, which is what all the 6ah and higher batteries all are now.  So if you have a high demand 18v one+ device you are stuck with 5ah which doesnt last long on the lawn movers like my ryobi one that is only two year old and now redundant.  So really its not one+ it is two+.  And nowhere can I find the ryobi or bunnings are admitting to this.
Re: Ryobi 18v batteries compatibility
Hi @Medsy,
As far as I am aware, that mower will still accept the current range of batteries in the same amp-hour range that it was initially bought out with, which was likely 5Ah. The 8Ah battery is physically larger in size and suits the vast majority of Ryobi one + tools. In some situations, it might not fit in a machine where the body encroaches too closely on the battery. They've been bought out to offer extended run-time in tools that accept that size of battery. Your machine was likely produced on the cusp of the new, larger-capacity batteries being developed and can't be retrofitted with them.
I apologise that the batteries you've purchased do not fit your machine, and I trust our in-store team would be more than happy to accept them for a return due to the mix-up.
Hi again @Medsy,
Nothing has changed with the One+ system regarding the offering, apart from it being extended to now include higher-capacity batteries. All tools that have been produced in the past still have the very same batteries available for them today. Your Ryobi mower was designed and sold with 5Ah batteries. For an extended runtime, additional 5Ah batteries can be purchased. Though I understand a single higher-capacity battery would be preferable.
I'm not aware of over 25 devices not accepting the new, larger capacity and sized batteries. But, this is definitely something I will look into, as if it is the case, it certainly affects being able to say that the batteries suit all products, and we need to specify that the high-capacity batteries might not suit all tools.  Annecdotally, I have the 8Ah battery, and it suits all my tools, including the circular saw, detail sander, random orbital sander, edge trimmer, blower, reciprocating saw, brad nailer, drill driver, hammer drill, and impact driver.
As mentioned, thanks for bringing this to our attention.
