magsc
magsc
Community Newcomer
magsc
Hi i have an ozito drops saw model 1621. 210mm. I have had it for 5 yrs so out of warranty. THE  blade guard has stopped moving all the way up. JUST MOVES A few inches. I've tried tightening the middle screw but it's not that? Can't find any thing in manual. The red plastic part that you move under handle still moves ok? Hiw to fix adjust?
Re: magsc
Hello @magsc
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your drop saw.
I'm sorry to hear your drop saw is acting up. A drop saw (mitre saw) blade guard that refuses to move is sometimes caused by a build-up of sawdust, a bent mechanism, or a faulty spring. The most common solution is to clean and lubricate the pivot points, check if the guard link arm has popped out of its channel, or tighten loose screws on the assembly. It's also possible that it has a default safety mechanism that might have gotten triggered. Look carefully and observe if anything is getting in the way of the blade guard as it rises.
Let me call on our experienced members @Nailbag, @Noyade, @AlanM52 and @Dave-1 for their recommendations.
AlanM52
Re: magsc
Hi @magsc,
The first thing I recommend is purchase this (or similar).
Can of compressed air with extension tube which will give you good access to get right in there and clean out everything.
Then proceed as @EricL advised to lubricate the pivot points.
