suggestions on insulating and making my fishing workarea in my garage look more complete
Corey5
Hey guys my carport is a two door carport one half is for a car and a bit of excess storage the other half I’m wanna half block off and insulate so I can help cool it down I’m in Darwin it gets bloody hot.
wanna make it look a bit more complete and professional and it all needs to be renter friendly thanks
Re: suggestions on insulating and making my fishing workarea in my garage look more complete
Welcome to the Bunnings Workshop community @Corey5. It's wonderful to have you join us, and many thanks for your question about insulting a garage.
Darwin's heat makes this a tough one, and you have already done a decent job carving out a usable space with what you have. The hard truth, though, is that even in a single garage with one door, properly insulating and cooling it is difficult. In a two-door carport like yours, it becomes even harder because any effort you put into one side is largely undone by the other uninsulated door and the open nature of the structure.
To genuinely insulate a garage door, you would normally need to build a stud wall in front of it, fully seal it, and insulate it with something like an R2.5 batt. In your case, you would also need to build an internal stud wall to divide off your work area from the rest of the carport and insulate that wall as well. That is a fairly substantial build even for a homeowner, and it really pushes beyond what most people would consider renter-friendly. Anything less than fully sealing and dividing the space tends to just slow heat transfer slightly rather than meaningfully improving comfort, especially in tropical conditions.
That said, you can still make the space feel more complete, more professional, and more usable without fighting a losing insulation battle. Visually and functionally, the biggest win will be continuing the metal racking along that wall and getting as much gear as possible up off the floor. Extending the racking system across the whole length will instantly make the area feel intentional rather than temporary, and it will free up valuable working space. Organised vertically with the Rack-It system, the area will feel cleaner and far more practical for rigging rods and working on gear.
In terms of heat comfort, airflow is realistically your best friend here. High-velocity industrial fans make a massive difference to how the heat feels, even though they do not lower the actual temperature. Mounting a fan above or near the storage units to push air directly across your work zone will make long sessions far more bearable. In Darwin conditions, airflow often matters more than insulation unless the space is fully enclosed.
If you do want to experiment with renter-friendly heat reduction, reflective insulation on the back of the garage door is about as far as I would go. Products designed for garage doors can be lightly fixed using silicone dabs or removable fixings, which should be reversible when you move out. It may help reduce radiant heat coming off the door surface, but with another uninsulated door nearby, expectations need to stay realistic.
