How to use Yates BuffaloPro Lawn Fertiliser Hose?
pedroea
Hello,
I applied Yates BuffaloPro Lawn Fertiliser using a hose-on applicator to a 100 m² lawn.
The fertiliser was applied in two applications, one week apart, using half a bottle each time.
Since then, the lawn has deteriorated and looks worse than before.
Could you please advise what might have caused this?
Thank you
Pedro
Re: Yates BuffaloPro Lawn Fertiliser Hose
Welcome to the Bunnings Workshop community @pedroea. It's wonderful to have you join us, and many thanks for your question about lawn fertiliser.
If possible, could you share a photo of what the lawn looked like before applying the fertiliser? It’s clearly browning off now, but without knowing its condition beforehand, it’s difficult to pinpoint what has changed and by how much. For example, was the lawn evenly green prior to application, or were there already brown or thinning patches that have since expanded?
It’s worth noting that fertiliser doesn’t usually cause this type of decline on its own when applied at the correct rate, particularly a hose-on product used as directed. More often, browning like this points to an underlying issue that was already present. Common causes include heat stress, insufficient irrigation, compacted soil, or root stress. If the lawn was already struggling due to hot weather or lack of water, fertilising won’t correct that and can sometimes make the symptoms appear worse if watering wasn’t increased.
I do note that under precautions, it lists: To avoid burning, do not apply if the maximum temperature exceeds 30 °C or if the lawn is suffering moisture stress. Is it possible that the product could have been applied on a day that exceeded 30 °C?
How has the lawn been watered recently, especially on hotter days? Buffalo lawns, in particular, need consistent deep watering in warm conditions, and dry stress is a common cause of sudden decline.
If you can provide a bit more detail about the lawn’s condition before application, along with how it’s being irrigated, and ideally a photo, that will make it much easier to work out what’s going on and how best to get it back on track. At this point, it would be best to apply a seaweed-based tonic, such as Seasol, to help with stress and ensure adequate irrigation. The soil should remain moist, but not wet.
I've reached out to the Yates technical team, and they encourage you to contact them for further assistance.
