What to spray on Peach and Orange trees?
Charley1
I have 2 small peach trees and 1 small orange tree. Do I need to spray them all with lime sulphur for leaf curl and anti rot. When should I spray them. Thanks
mich1972
Re: Do I need to add a wetting agent to Yates success ultra?
@Charley1   When spraying an insecticide, fungicide or weed killer, it’s ok to add a few drops of dish washing liquid to act as a wetting agent to help it stick to the foliage.
Castile Liquid Soap is usually the best one to use 😊 if you can’t get it dishwashing liquid is fine.
mich1972
Re: What to spray on Peach and Orange trees?
@Charley1  Using both fungicides might be a bit too much.
lime Sulpher is more for the deciduous fruit trees and also good for mites.
The Anti Rot is more of a systemic fungicide for Collar Rot ect.
@Noelle  Just confirming with you Noelle, two different fungicides for different fungal diseases. They are also good as a preventative spray, just not together as it may be too much ? 😊
Noelle
Hi @mich1972 & @Charley1
Definitely NOT both together.  Anti rot usually isn't necessary unless there is fungal rotting of the wood of the tree, as would occur with collar rot.  A good general garden fungicide (lime sulphur, copper spray, etc) would be just fine to control the normal range of fungal diseases deciduous fruit trees like peaches could experience.
Re: do i need to add a wetting sgent to yates success ultra
Hello @Charley1
Adding a wetting agent depends on the insect attacking your plant. If you look at the instructions at the back of the bottle, you'll see an asterisk symbol next to the insect's name. For example, the apple moth has a single asterisk next to its name which means that you'll need to add a wetting agent when spraying it on your plant.
The others that have two asterisks on it means that you'll need to use white oil. White oil is an agricultural oil and is meant to be used for gardening only.
mich1972
Noelle you are the BEST 🌿🌿💚💚🥰
