Hi, bought the ninja slushie max from Amazon (thought it was Australian) and it had an American plug
have been told that I won't be able to use it without risking it blowing up. Any advise available would be appreciated. Thank you
Hi @shah2,
The product you've purchased is designed to run on 120 volts, whereas Australian power is 240 volts. The plug shape is only part of the issue. Even if you use a simple plug adaptor, the appliance will still receive more than double the voltage it is designed for, which can cause it to fail, overheat, or in the worst case cause a fire or permanent damage.
I'd suggest you return the product as it is not suitable for use in Australia.
Thank you Jacob, I think it's going to cost me a fortune to send it back. But I'll look into it.
