Hi team,
I have a very small kitchen (room for one person only!) and wanting to somewhat maximise the storage space available.
I currently have a full size dishwasher, which is old and performs poorly, needing replacement anyway, as it was damaged by the previous tenant. I am looking to replace this with a single Dishdrawer or some other type of compact dishwasher (not necessarily the F & P, as there are other brands which make compacts in a similar size).
As there is currently a full sized dishwasher in the space and a single Dishdrawer / compact dishwasher takes up much less space, I will need to build a shelf of sorts, or a box inside the cabinet for the single Dishdrawer to sit on.
Dinensions of the cabinet internally (ie usable space inside) are:
-840mm from the actual floor to the ceiling of the cabinet (it’s an open cabinet without a cabinet base or kick, but I’d plan to install a kick to make it the same as the adjacent cabinet).
-600mm side to side
-575mm front to back
dishdrawer is
410mm (height)
599mm (width)
573mm (depth)
again, other compact models in other brands are similar sizes (omega, Kleenmaid and there was another one that I forget the brand name of, I’m just stating the Dishdrawer dimensions as an example).
What would be the best way to build said shelf or box inside the cabinet?
Would a box (or a small cabinet) within the existing cabinet be a better open than a shelf? I could then build a drawer into the box/cabinet to increase available storage. Obviously needs to be a moisture resistant material and something that can support the weight of the Dishdrawer (approx 30kg).
for reference, this entire kitchen is less than 5sqm. It is a tiny, but I am far too lazy to not have a dishwasher so I am really trying to make this work and make it all fit.
Hello @karinas
I suggest installing a Kaboodle 600mm 1 Drawer Base Cabinet. It's very close to the measurements that you need to fit your single dish drawer. Should you need more space for height the cabinet legs are adjustable and can be lowered down to what you need. I've placed an image below to give you a better idea of how they can be put together. Please note that the cabinet depth is 580mm with the door attached.
