So my kids we’re treated brand new bedroom suites when we built our house. Which was great until one of their friends got a loft bed early last year. As my daughters decided at NYE they wanted seperate rooms again so I had to work out the layouts etc. So I did my research and given their single bed frames are in perfect condition I decided to convert them to loft beds.
I used spare pallet wood, leftover timber from the playground I made and also spray painted their old cot to add some feature to my eldest daughters bed. Have spray painted a desk for my other daughter so waiting to add that. Plus find the right lights to have under the bed to provide light at nighttime. Will be battery operated. Thinking those LED strips. Still a couple of touches to go but the girls love them and haven’t had any issues.
Hi @jovybsb,
Hopefully, @Tara86 will get back to you on those steps. It appears that, essentially, she created a frame to support the lower edge of the bed (just like it was sitting on the floor) and then elevated that on the legs. The method you use will be determined by the type of bed you have, so if you'd like to post some images of your bed, our helpful members will be able to provide some ideas on how you could do the same.
Thank you Mitchel! This is the bed I’m wanting to use, it’s a double bed from IKEA.
Hi @jovybsb,
Thank you for sharing the image of the bed. Elevating a standard bed into a bunk or loft configuration can be a complex project, particularly when using furniture not originally designed for that purpose. Safety should always be the top priority, especially if the bed will be used by children.
I recommend starting by consulting the manufacturer or referring to their product guidelines to confirm whether modifications like this are feasible and safe for the specific bed you have. The manufacturer may provide critical information about weight limits and structural considerations.
If they confirm that such a conversion is possible, it would be best to engage a qualified carpenter or builder to construct the supporting frame. This ensures that the frame is properly reinforced and stable. Key considerations include securely supporting the bed base, evenly distributing weight, and anchoring the structure to prevent movement or tipping. A professional will also be able to advise on the best materials and construction techniques to ensure the project is completed safely and to a high standard.
In regards to Tara's project above, I've put together some renders of how she might have assembled her frame.
Thank you! That is very helpful!!!
