Welcome to the Bunnings Workshop community @lidy16. It's wonderful to have you join us, and many thanks for your question about constructing a bed frame.
It appears the majority of the froma is made from 42 x 42mm DAR Pine, and the dowels look to be around 12mm. It's best to break the project into sections so you can better understand how it's constructed. I've put a couple of renderings together for you below that should hopefully assist.
You'll begin by determining the frame's dimensions to suit your mattress. Then, cut the 42mm timber for the horizontal and vertical rails. Those will need 12.5mm holes drilled in them to accommodate the dowels. The dowels get inserted, and then the rails screwed together. The four sections can then be joined to create the frame. I'd suggest 60mm timber screws would be an appropriate choice for the projects.
hi mitchell
thanks for the response
the problem is i don’t hv any of the tools needed to prepare the frame
does bunnings provide the cutting of the woods at all??
TIA
Hi @lidy16,
As per the popular topic Does Bunnings cut timber to size, many Bunnings stores have a timber cutting service but the service is for helping you to get your timber home. Because of the nature of the saws, precise cuts are not possible.
This project would be a great way to learn new skills. I would recommend starting with the guide How to use power saws. Have a read and let us know if you have any questions about next steps.
