I am hoping to achieve the look in the photo hopefully find the dog too!
I don't have a nail gun so I don't know if it's still achievable. I don't want to get boards too thick so it doesn't hang off the skirting boards.
What products would I need to hammer in nails and which liquid nail products are recommended?
Is there wood that i should use for this project? Looking for a cheaper option here as the boards won't be exposed. They will be painted.
If your starting off with a plain wall gyprock with skirting board. Consider taking the skirting board off as it may not match the timber above it.
Now see the large in fill panels under and between the boards? Well that can be your gyprock wall painted and just framed by the boards.
Or use some really nice lining panel cut to size.
https://www.bunnings.com.au/900-x-1200mm-12mm-lining-panel-white-mdf-primed-batten-25mm_p0281886
As for the boards well you can buy MDF panels( much cheaper than timber. ) of various thickness to suit your designs. Simily cut it into strips / plank like panels.
https://www.bunnings.com.au/3600-x-1200mm-12mm-mdf-panel-standard_p0593584
Or another product called CUSTOM wood is more inexpensive again.
https://www.bunnings.com.au/customwood-9-x-2400-x-1200mm-raw-e0-mdf_p0590024
Ordinary Liquid nails is fine for the job used very sparingly in case you want to take the panels off later the gyprock wont be trashed.
Thin nail gun is ok Or thin gyprock screws (will hold better than nails ) Liquid nails not really needed as this is light decorative work after all.
A must have is No more gaps. It will also act like a weak glue.
I would buy so (no more gaps) to caulk between the mdf and wall and any joins or gaps. iI is paintable so it is good to have.
Nice project
Love to see the finished job.
Hello @Purplepolkiri
It's great that you've received excellent advice from @Jewelleryrescue. I totally agree with the materials suggested, it will be perfect once cut into shape and glued or nailed to your wall.
Here are some discussions regarding wall moulding you might find useful:
For the large panel going across horizontally how should the edges look? Do they get cut at an angle? Sorry i was unable to find the information. I plan to extend this pattern to the entire room however for now I will be just trialing on the one wall.
What nails should be used if just using a hammer?
If you are going to do the room in stages and want 45 degree joins at the rails room corners dont forget to pre cut them at 45 degrees to add the design around the room. Once they are on the wall it is quite awkward to cut at 45 degrees.
I would use bullet head nails that hammers into and below the timber surface, so they are invisible when you use a smear of no more gaps over the nail hole. To hammer them in slightly below timber depth 0.5mm use a nail punch.
You can use smaller 30mm nails too depending on the thickness of your panelling. You can also use thinner nails but they will bend more easily if miss struck. They are only holding light decorative panels so the nails dont need to hold a house up.
https://www.bunnings.com.au/paslode-40-x-2-0mm-500g-bright-steel-bullet-head-nails-460-pack_p2360397
As for the the inner flat panelling you can leave them square or 45 degrees this is a personal taste option here.or if you have a router with a selection fancy cutting profiles then make them as ornate as you wish. So look around at designs you may like them then learn how to achieve this at your need.
The top horizontal rail there are several pre made mouldings on offer at bunnings that are designed to sit flat on the wall. Easiest to use even if you own a router. and can makeyour own, Pick the best one to suit your flat panelling thickness under it and meets your interior design approval.
To make nailing easier, I suggest using a drill and making some pilot holes on the panel before putting it into place.
So far so good! Still in the process of painting but thanks so much for the tips!
Thank you so much for sharing that photo update. The wall and colours look fantastic!
