How to hang a 9 Kilo mirror with deep rims?
Ramma123
I have got a 9 Kilo mirror with a rim that is nearly 2cm.l need to install it into dry wall but cannot find anchors/hooks that stick out 2cm from the wall and can be inserted into the white holes in the back. How should I hang this mirror? If not hooks what other method can I try?
Any help will be much appreciated.
Re: How to hang a 9 Kilo mirror with deep rims
Hello @Ramma123
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your mirror.
I suggest looking at using Everhang 20kg Heavy Duty Solid Wall Picture Hanging Hooks in combination with Ramset 8 x 64mm Zinc Alloy Toggle With Screw - 2 Pack. If the hook does not touch the back of the mirror, I suggest putting some Zenith M8 Hot Dipped Galvanised Washer to increase its distance from the wall.
Here is a handy guide that will help: How to hang just about anything by @Adam_W.
