How to install castellated ceiling lining board?
mann
I want to make my tv wall like this
and planning to use the castellated claddding
https://www.bunnings.com.au/210-x-21mm-4-8m-tas-oak-castellated-ceiling-lining-board-composite-timbe...
How can i install it?
Re: How to install castellated ceiling lining board?
Hello @mann
Thank you for sharing your question bout the 210 x 21mm 4.8m Tas Oak Castellated Ceiling Lining Board Composite Timber - 4 Pack. Your proposed plan of installing it as a background feature can be done. However, I suggest mounting the TV bracket directly to your wall instead of the Castellated Lining. The lining board is a composite product and is hollow and will therefore not be a good base to screw into.
In order to assist you further, I've sent you an email with the installation brochure attached. I suggest installing your TV bracket first before you install the lining board. This will then make it a lot easier as you can just cut the lining to fit the bracket rather than the other way around.
The installation method is straightforward and only requires you to use countersunk screws to drill the lining board into your wall. The lining panels go over each other providing a seamless look and at the same time hiding the screws you used.
Here is a handy discussion that will help - How to wall-mount a heavy 75-inch 40kg TV by @Sugar
