Hello!
I am planning to paint the internal walls of an old house (circa 1920) would appreciate some advice in preparing the ceiling and walls. I have read through the other painting prep posts in the community forum, but am still unsure how to approach these:
There is some gap between the cornice and the ceiling, which I planned to caulk with Selley No More Gaps Interior filler.
Thank you in advanced for your help!
Good Evening @Curious_Bee
A 1920's circa house
Oh yeah! Love them.
Being from the 1920's you will probarlly find things are not quiet what you would expect in a house built in the last 50 odd years ![]()
Cornice may be uneven to start with. Sanding them back I would probarrly start by hand and persist with a lot of patience. I would also test the paint for the ceilng and walls for lead based paint just to be cautious. I just googled for lead paint test kits and got this -
"Note: Do-it-yourself household lead test kits are available and can be purchased from paint distributors and trade paint shops. These kits indicate whether lead is present or not however they are only guides and may not give a true or reliable reading."
To lesson the unevenness effect of the cornice you could paint ceiling and walls a closer matching white.
Ceiling rose removal of paint, do you have a photo of the ceiling rose? It may come down to slow work and more hand sanding.
The air vents and their coats of paint. 😕 yeah I can see the thickness of paint. I have seen "how to" videos of people cutting them out and then working on them (so the fine mesh behind teh course checkerboard) is restored. Depending on how far you want to go its back to hand sanding and lots of patience with a small wire... ugh (My bathroom air vents are the same and yeah I have pondered over how I would approach theat as well)
Horse hair plaster, it has ripples/slow waves and a style of its own. My grandparents house had their foyers ceiling made of it. I would stay with what you have used
Smooth and blend any repairs is the way I think of it.
Old houses are a bit more work if you want to keep the same style. Worth it for sure but I wouldnt expect things to be perfect (gives you some leeway in your renos)
One reason I suggest hand sanding is because a mechanised sander may clag up/heat the paint and just make it harder. Plus you could wear into the existing plaster. Its a pain I know.
Hi @Curious_Bee, you’ve already received some very solid advice from @Dave-1, and I’d echo a lot of what he’s said.
Homes from the 1920s really do come with a lot of character, but that also means they were never finished to the same flat, sharp standards we expect from modern plasterboard construction. Cornices, ceiling roses, and wall corners were often hand formed on site, and after decades of repainting, those crisp lines you’re aiming for can be extremely hard, and sometimes unrealistic, to fully restore.
With thick layers of paint on cornices, roses, and vents, sanding alone is often frustrating and slow, especially if the paint has hardened over many years. Careful hand sanding is still the safest approach, as power sanding can quickly chew into the softer plaster underneath and make things worse. In many cases, the goal is to reduce the visual build up rather than completely remove it. Trying to chase perfection here can easily lead to more damage than improvement.
For cornices where paint has softened the edges, it’s worth accepting that some definition has already been lost. Light sanding, minor filling where needed, and then repainting neatly is usually the best balance. As Dave mentioned, using similar tones for walls and ceilings can also help visually minimise unevenness rather than highlighting it.
Wall corners in older homes are rarely straight. Once you start sanding them aggressively, it’s very easy to create that rounded effect you’ve noticed. At this point, I’d suggest stopping further sanding on corners and instead focus on making them consistent rather than perfectly straight. Minor imperfections tend to disappear once painted, especially in softer or matte finishes.
Your approach to patching the horse hair plaster sounds appropriate. Topping compound is commonly used for this and, as long as it’s well keyed in and feathered out, it should perform fine. These old plaster walls naturally have subtle waves, and trying to flatten them completely can make repairs stand out rather than blend in.
The biggest takeaway is to adjust expectations slightly. After decades of paint and age, it can be very difficult to re establish sharp architectural detail without extensive restoration work. In most cases, sympathetic preparation, neat painting, and accepting a bit of historical character will give the most satisfying result. Once everything is painted, many of these issues become far less noticeable than they seem during prep.
It’s also worth adding a general note of caution given the age of the home. Houses of this vintage can contain asbestos in a range of materials, and it’s not always obvious where it might be present. Even if previous owners have had some testing done, it’s safest to assume that any older wall linings, ceiling panels, backing boards, or patch materials could potentially contain asbestos unless proven otherwise.
Thanks @Dave-1 and @MitchellMc for sharing your experiences!
Good to know that I will just need to adjust my expectations and put in some labour to achieve consistencies across the walls and ceilings.
I have tested the wall for lead and so far they have come back negative, but I am still a bit weary and will be caution when sanding back the walls.
This is a corner of the ceiling rose where we have scrapped off some of the old paint to reveal the plaster which took a couple of hours!
So far from my understanding, I have two options:
(A) Try Peel Away 8 to see if it would be more efficient in removing coats of paint on the ceiling rose, or
(B) Gently sand back as much as possible. If encounter paint that has peeled off, use Zinsser Peel Stop to seal it, then patch, sand and lastly prime before paint.
What would be your advice?
Thanks again for your help!
Hello @Curious_Bee
I would go with step (B) and that is to gently sand back use Zinsser peel stop then patch, sand and prime. It would be labour intensive, but if carried out with patience you should achieve a nice clean finish.
