Metal spray paint is getting off if I scratch the surface
mk1
Cultivating a Following
Hello,
Once again I am back with my very basic question. My dining chairs have got metal legs, which I painted them with dulux dura max spray paint.
The problem is that the paint is easily scratch able and I need something permanent.
can you please advise what type of product I shall use.
Please see pictures.
Thanks,
MK
Re: Metal spray paint is getting off if I scratch the surface
Hi @mk1,
All paints applied from a spray can scratch to a certain extent. Adding a clear coat such as Dulux 325g Duramax Gloss Clear Spray Paint will provide an additional buffer layer to help prevent the paint scratching. Alternatively, epoxy enamel spray paint is harder wearing than the enamel spray paint you have used already. However, it doesn't come in finishes like the Duramax product.
What type of surface did you spray onto and what preparation did you use on that surface? Did you happen to use the Duramax primer before painting?
mk1
Hi @MitchellMc,
I didn't use any primer before painting. Just used the Spray Paint as I showed in the picture.
Thanks for your suggestions, I will use Dulux 325g Duramax Gloss Clear Spray Paint as advised.
MK
