Need wall panel ideas
Revi
hi team ,
happy new year
I have 3 mtr by 3 metr wall opposite dining and I wish to do a simple one all panels and hanging 65 cm by 45 cm glasses photos .photo frame bit heavy . Which panel suits for my purposes
thank you
Revi
Re: wall panel ideas
Hi @Revi, happy new year to you too, that sounds like a lovely feature wall idea and a great way to personalise the dining space.
From what you have described, it sounds like you are planning to panel the full 3 m by 3 m wall and then hang several reasonably heavy framed glass photos over the top. That is definitely achievable, but the best panel choice depends a bit on the look you are aiming for and how you want to fix the frames.
Common options for this type of project are VJ panelling sheets. MDF panels work very well for feature walls, are smooth and easy to paint, and give a clean, timeless look. They also add a bit of extra rigidity over the plasterboard, which helps when hanging items.
For the photo frames, the most important thing is how they are fixed. Even with panelling installed, any heavier frames are best fixed back into the wall studs where possible. That gives you the most secure result and avoids relying only on plasterboard fixings. If the frames are moderately heavy, fixing through the panel and plasterboard with good-quality wall anchors can still work, as the panel does add some strength, but studs are always the safest option.
Before recommending a specific panel type, it would really help to know what style you are going for, for example modern, classic, or Hamptons style, and whether you are thinking of full-height panels, half-height with a dado rail, or simple vertical panels. If you can share that, we can point you in the right direction and make sure whatever you choose suits both the look and the practical side of hanging your frames securely.
Revi
Thank you ,
Just I selected two items finally go any of one. I think some stage need cut for size . Which cutting mechine best ? I have one mechine. I can attach photos of that one . Please advise me
thank you
Revi
Hi @Revi,
For the black acoustic panels, you can use a fine-toothed saw or a circular saw to cut them. For the Hardie Groove lining, you can either use a score and snap knife or a circular saw with a blade designed for cutting fibre cement. With either of these boards, you could use the spring toggles I linked to above.
Revi
Thank you for your reply
which sealant good for outdoor gap filling
1, between concrete floor and composite dec
2, between composite deck sides cover area
i have attached photos with green mark
thank you
Revi
Sikaflex 11FC would probably be the best sealant for that job @Revi.  However, bear in mind that any water that flows through the decking boards at the top would then be trapped inside the area.
Revi
Hi ,
I finally decided go with wooden wall panel . I can upload pictures. My wall gypsum so which glues best and which screw best prefer screws black colour
