Is Bunnings 42mm x 42mm Merbau suitable for joists for low level decking?
Henry1
Hi all, I'm doing some low level decking and wanting to use the Bunnings 42mm x 42 mm (pencil rounded) Merbau timber for the joists. They will be on a concrete slab but I'm really limited to the height, hence the need for the 42mm x 42mm.
I propose Bunnings mini feet for the bearings.
I'll be applying Ekodeck boards (180mm width) on top with 6mm gaps. Area is 22m2.
Height, off the concrete, for the joists will range from 10 mm to 40 mm (Yes, very low level).
I'll be applying bearer protector (CA group) G-tape onto the tops of the joists.
The concrete has a drain in the middle with slope towards the drain from each side.
Most of the decking (say 2/3rds) is permanently in the dry, under cover. The exposed area cops the Perth weather.
The merbau timber is rated to Class 1. Initially, I was looking at a H4 rated softwood (Radiata Pine) for the joists (due to the low height off the concrete) but from what I can see, the span for them is 250mm and that would involve around 200 bearers.
Wondering what the span capability is for the Merbau hardwood and whether people more experienced than I am, would say it's up to the task given the low level.
Your experience and recommendations are welcome
Re: Is Bunnings 42mm x 42mm Merbau suitable for joists for low level decking?
Hello @Henry1
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your low-level decking project.
I'm afraid the 42 x 42mm 2.7m Pre-Oiled Merbau Solid Screening will not be sufficient for your project. It is rated for fencing not for framing and will therefore not be able to carry heavy loads. A close alternative would be the 90 x 45mm Outdoor Framing H3 Treated Pine. Can you please tell us the maximum and minimum space in height you are working with?
If you were to use the 90x45 and the frame is built with the 45mm side up, you would be occupying a space of 90mm + 23mm which equals to 113mm and whatever is left underneath will be the air gap of your deck. If you were to build it with the 90mm side up the frame would not be as strong and you would need to use more support to hold the frame and decking panels in place.
Would it be possible for you to post a few photos of the proposed decking area? We might be able to offer recommendations on how to lay it out.
In the meantime, I suggest having a quick look at these guides - How to build a low-level deck by @Adam_W and How to build a deck by @MitchellMc.
Good Afternoon @Henry1
I am thinking of a few pics that showcase the area. The 42mm square merbau would not be suitable as @EricL has mentioned.
When you say 22sqm but later mentioon 200 bearers I am a bit confused.
Length = ?
Breadth = ?
Height from concrete to door sill level = ?
All help us out in picturing what you have.
Henry1
20250829_065504.jpg20250829_065453.jpg20250829_065527.jpgScreenshot (164).png
Henry1
Hi Dave
Photos just posted. I have a 100mm gap from the concrete base to the swing of the back security door. The concrete is curved so flow goes under the decking to the middle, to the drain (pictured). As a result, the outer area of the concrete - which cops the weather - is relatively higher and allows only about 10-15 mm for a bearer under the joist.
Also in the photos posted is a screenshot of H4 radiata pine I could possibly use for the joists, given the low level ? Using these though will mean more bearers. Any help on span recommendation would be welcome. From what I could glean from google was 250mm spacing meaning 4.8 m (Width) x 4 per metre x 10 joists  = Up to 192 bearers (plus I'll need some for noggins).
Area is 4.8 m W X (Up to) 4.5 m L (end is rounded and gradually reduces to the minimum L 3.6m).
Joists will be at 450mm
Hi @Henry1,
Unfortunately, you'll notice in the Terraframe Install Guide & Span Tables that the 45x45mm pine doesn't have a listed span because it is not capable of supporting an elevated load.
In this situation, where you have only 100mm of height to work with, you would be better off ditching the idea of having both joists and bearers and treating every framing member as a joist, where it is directly supported from below and does not structurally support any other framing member.
If you opted for a joist-only deck frame, you could use the 70 x 45mm MGP10 H4 Treated Outdoor Structural Radiata Pine, which, according to the span tables I linked to above, can span 750mm as a continuous span, meaning it runs over multiple supports, not just two.
This means you would need to support each joist every 750mm with a Builders Edge 25-40mm Minifoot Pedestal Foot
You would then add noggins and rim-joists to keep all your framing stiff and parallel. As these framing members would not directly support weight, they are not required to follow the span tables.
Can you let me know which way you want the decking boards to run in relation to the door? A quick top-down drawing with the measurements and oritentation of the decking boards would be great.
With this information, I would be happy to throw together a basic plan for your deck frame.
Let me know what you think.
Henry1
Hi Jacob
Thanks for getting back to me.
I'm planning on using Ekodeck summit 180mm Width planks. (23mm H)
Basic plan is pictured. I was playing with putting a breaker board in (pictured), to reduce some wastage as the ekodeck are 5.4 m lengths.
I was thinking 1.8m Length from the house then a breaker board then completing the rest.
I will need some mini feet or spacers in particular in the middle as the concrete slopes in from the outside (think skate bowl)Screenshot 2025-08-29 075602.png
Hi @Henry1,
I've done up a quick framing plan using the 70 x 45mm MGP10 H4 Treated Outdoor Structural Radiata Pine.
With this orientation, each joist would need to be supported every 750mm, which, at this width, would require 8 supports per full-length joist.
The breaker board could be a good idea to reduce wastage, although you would need to add a second joist wherever it is situated so the board is supported across its full width. If the cost to add another joist, with 8 supports, outweighs the cost of the wastage, then it would be worth doing.
Henry1
Thanks again Jacob
I'm not sure I'll be able to accommodate the 70 mm  joist height at the outer edges (opposite edges from the door). .
. The problem there is if I don't use spacers, the boards on the concrete will block drainage flow, leaving water to pool.
Next to the door is fine as it's well under cover.
I'll do some testing but I'm not confident there's enough height on the outer edges.
Hi @Henry1,
Would you be willing to change the direction of the decking boards?
If so, then you could run your joists perpendicular to the house, which would allow any water to flow between them.
On the outer edges where there is minimal height, you could sit your joists on window packers, then bolt them to the concrete for stability using angle brackets.
Outside of this approach, unfortunately, I can't see any way of making it work besides cutting out the concrete to create more height for the frame.
