Low-level deck that needs to support tons of weight
Adog
New Contributor
Hi Brain trust,
I’m going to be building a low deck on this concrete slab so bearers and joists same level. It measures approx. 5160 x 4260. I have approx. 150mm from concrete to top of deck to fall in line with sliding door frame
I’m thinking of using:
Galvanised brackets
90 x 45mm H3 pine so I’ve got room for adjustment and levelling
into concrete
M10/M8  75mm coach screws bracket to joists/ bearers
I will be running the decking long ways (Specrite Merbau Decking)
My challenge:
My significant other has decided she loves a outdoor concrete table 2m long x .900 wide (145kg!)
Concrete bench seat 1.6m long x .400mm wide (60kg!)
Can fit maybe 8 around the table (8 x approx. 80-90kg) although this will hardly ever happen outside of christmas time
145+60+ (8 pax x 90kg average person weight) = 925kg
My question is, is this doable with the products I’m using and also how should I strengthen the frame? Spacings? Doubling up bearers/ joists etc?
The table will be sitting in the middle of the deck so will I have only strengthen this area only?
This is a large deck and i am trying to do it the smartest way with as little punishment to my hip pocket as possible.
Any and all help much appreciated.
Thanks in advance
xixUbhzlQeO4GQOxNM0+aw.jpgl7jeEOyWS5af65ryIzLN7g.jpgUntitled.jpegBlWqmWvHSQ2nmNYYwmbfwQ.jpgGb0DV%z2Q5qY2XKvZ4sSXg.jpg
Re: Low deck tons of weight
Welcome to the Bunnings Workshop community @Adog. It's wonderful to have you join us, and many thanks for your question on deck construction.
A standard raised deck built to code is designed to hold around 200kg per square metre. For your deck, the simplest solution would likely be to double up the joists where the table will be sitting and space them so the legs can sit upon them instead of the decking boards. If you are happy to have the table in one location, it will be a simple matter of having joists underneath the legs and then a bracket or, even better, a Builders Edge 25-40mm Pedestal Foot Minifoot directly under the legs. That will transfer the table's weight into the pedestal feet and the ground instead of the structure. The pedestal feet can hold up to 200kg per foot.
I've put together a rendering below to illustrate how you could reinforce the area. I'd suggest the best option might be to build the deck normally and then add in the additional joists and supports in the area where the table makes contact. As mentioned, you'll want the feet above the joists and not in between them.
Adog
New Contributor
Hi Mitchell,
Thank you for the fast reply and for the render. Two more questions if I can please?
1.Whats your thoughts on the galv bracket spacing overall?
2.Regarding the joists should I be putting them throughout the deck or just where the table might go as per your render?
again really appreciate the help.
cheers.
@Adog,
Most of our members space their brackets at a maximum of 1000mm mark. For a stiffer frame, you can place them more frequently. Or to limit their use, you can check timber span tables for the max span of 90 x 45mm. If you start pushing the limits though, you'll end up with a spongy deck that flexes.
As long as a sufficient amount of brackets are used, you shouldn't need to use noggins between the timbers throughout the whole deck. Once again, though, they'll add rigidity to the structure if you do. Since this is a low-level deck, the rigidity is not of such a concern.
Adog
New Contributor
Hi Mitchell,
That’s great information. Thanks again for the help.
Keep us updated, @Adog, and reach out if you need further assistance.
I look forward to seeing the finished deck.
Adog
New Contributor
Cheers Mitchell.
I’ll update with a photo or two when complete.
