What insulation to use under new corrugated patio roof.
Karoshep
Hi, removed damaged laserlite roof on patio and replacing with corrugated instead. Looking at insulating between the battens and new corro. I was looking at this insulation - Ametalin Thermal Liner Roof and Wall Shed Insulation.-but there will not be an air barrier between the insulation and the corro except the gaps in the corro profile. Will this do the job without causing moisture issues please? Thanks for your help.
Re: What insulation to use under new corrugated patio roof.
Hi @Karoshep,
Have you got any photos of your patio roof that you can share? The description helps but seeing it is really invaluable in determining the best product and methods for your specific situation.
I note in the ThermalLiner Installation Guide that -
"Installation can be above the battens, but performance may be reduced, and problems may arise under certain environmental conditions. Specifically, condensation forming under the roof may pool behind battens. Condensation may also form on the underside of this product where contact is made with the roofing material."
If you are unable to create an air gap, then condensation can occur where the liner is in direct contact with the roofing material.
If the circumstances of your installation do not allow for an airgap, you may need to look at alternatives such as those shown in some of these similar discussions that you might like to check out:
Once you can upload some images, we can look at the situation and see if there is an alternative option that could be better in your situation.
Let me know if you need a hand uploading images.
A note for our New Zealand readers - The use of foil-faced insulation products is banned in New Zealand.
with the laserlite-this has been removedwith the laserlite-this has been removedawaiting the new colourbondawaiting the new colourbondnew batonsnew batons
Hi Jacob, thanks for the advice. I have attached pictures with and now without the laserlite. The new roof is colourbond. I did see that advice on the thermal blanket hence my questions. Thanks.
