hi all
We're using repurposed concrete chunks to crazy pave a pathway - these are around 6-7cm thick. What product would be the best infill to put between them to lock them together?
Hi @Taleya,
A good approach for infill would be to first fill the majority of the gap depth with mortar. Since your pavers are around 6–7cm thick, using mortar to bring the infill up to around 5mm below the surface of the pavers will make it easier to pack out the area without using excessive amounts of finer material. Once the mortar has cured, you can then use a tile grout to fill the final 5mm and achieve a finer, more finished look between the pavers.
Grouting this top layer works much like tiling — just be sure to wipe off any excess grout from the surface of the pavers before it dries completely, using a small amount of water and a scrubbing brush or scourer. This two-step method not only saves on grout but also gives you a cleaner, more durable finish.
Here's a helpful guide: How to lay crazy paving.
I do not think tile grout would last outside in these conditions. This is a completely exposed, heavily trafficked walkway serving a garden area with carts and heavy weights.
I've looked at that crazy paving link, but it's a completely different scenario to what we are doing, the only similarity are the names.
Are you bedding these chunks of concrete into a mortar base @Taleya? Typically, you would lay a 40-50mm bed of mortar and place your concrete on it while it is still wet. Once dry, the pavers will be locked into position. The grout is then used to fill the voids between them, helping to lock them together, rather than being the sole structural support. The mortar bed is what keeps them in place, rather than the grout, as its primary job is to fill the aesthetic gaps between the concrete.
Exterior tile grout is designed for use in exposed outdoor applications and should withstand heavy traffic well. It's used on all outdoor tiling projects, whether for patios, balconies, or walkways. The only thing stronger than a standard tiling grout would be an epoxy version, though these can be trickier to apply as cleanup is less forgiving.
If it's a bit of a rustic crazy paving path, you could choose to infill and grout with a mortar or cement, though these are more commonly used for bedding paving rather than grouting between them. My preference would be to use cement instead of mortar, as mortar is fairly sandy and rough.
My suggestion would be to use Dunlop 15kg Mid Grey Wide Joint Grout as it's specifically designed for outdoor crazy paving. In saying that, though, the pavers/concrete must be well supported on compacted ground and a layer of mortar for it to work effectively and not crack.
The chunks (actually from a previous 1950's poured path) are being laid out on a sand base with a compacted road base sub. We were thinking more crushed dust or similar between the chunks
That could work @Taleya. My only concern would be your ability to compact that material between the chunks. Without being able to compact it sufficiently, the chunks might move over time. I would suggest adding the crusher dust in 20mm layers and watering it in well between them.
Hi @MitchellMc , I have some mortar questions. I also have some crazy paving I need to lay on top of a concrete base. The pavers are 20mm thick and I was looking to use anywhere between 30-40mm of mortar. Two quesions on this, does this hight of mortar sound correct and also is the mortar you added to your previous post the one to go for(mortar)? Also I have some mesh cobblestones I need to lay which is on a compacted base of road base (100mm of compacted road base). Shall I use the same mortar? and also what is the suggested thickness of mortar needed? 40mm? I am assuming that the mortar is not a problem sitting on road base an it will harden/stick okay to this surface?
Thanks.
Hi @Smoucha,
Standard mortar mix, like the one @MitchellMc mentioned, is also fine for this application and is fine for use over compacted road base. Anywhere from 30-50mm of mortar thickness is fine.
As long as the mortar is applied relatively evenly so that there aren't cavities beneath the paver, then you'll have a good, solid install.
@JacobZ - another query. With the mesh cobblestone work, it is likely to take a number of days to wet lay (with the mortar) on the compacted road base. We will wait to grout once all completed. Will it be a problem if we get some rain during this time? or would it be best to cover with builders plastic if raining? It is hard to find a full 3-4 day period I have in a row available that does not includes some form of showers here in Melbourne!
Also, we have a gap to the edge of some of the cobblestones (on mesh). It won't quite fit another cobblestone and I know I may have to cut them, which I am trying to not to have to do if there is any other options. The outer edge of the cobblestones will also need some sort of edge/support. What could be done here. Mortar? or other to edge them in. We are planning to either have crushed earth with some grasses (poa grass etc) and some stepping stones or even fake turf to give it some colour. *apologies, as this could be a seperate post but thought I may as well continue from my last question.
