Hello,
if I purchase an internal door and want to put some framing on it (just a border), will liquid nails hold this together or are regular nails required?
I am reading that PVA glue is better to use.
Please provide any advice you have.
Thanks!
Hello @james95,
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for your question about adding framing to your door.
I recommend using small fixing nails such as Paslode 40 x 2.0mm 100g Bright Steel Bullet Head Nails - 90 Pack or similar depending on the depth of the timber framing you'll be putting on. I recommend using Selleys 500mL Aquadhere PVA Wood Glue Interior Adhesive, it's an excellent adhesive when joining wood together.
