How to cut shelves for inside cupboards?
alibee
I want to add a few extra shelves inside my linen press, kitchen cupboards and my walk in wardrobe. I have a number of scraps of Custom Pine 16mm White Matt Carcass Particle Board MR as well as some pieces of Particleboard sitting around. What tools would I need to cut the particle board to size?
I'd been thinking about getting a jigsaw for the project but I'm not sure if this is the best tool for the job.
I'm not concerned if the shelves don't look perfect, given they'll be inside cupboards but do need the cuts to be fairly accurate so they fit snugly into the cupboards. I've not had a heap of experience with power tools and other than cutting shelves to size I can't imagine I will need a saw for much else as I live in an apartment.
Thanks.
Re: Tools and method for cutting shelves for inside cupboards
Hello @alibee
I propose using a standard handsaw for your project such as the Bahco 550mm Hardpoint Hand Saw. It has excellent reviews and is affordable, plus it is easy to control and has a reasonable length. Now the cutting may take a while with a handsaw, but you will have total control, and corrections can be implemented anytime during the cut. The trick is to take your time and cut on the line. Keep the rhythm steady and don't rush the cut.
The other tools you'll need are a tape measure, ruler or a Craftright 300mm Combination Square, plus a pencil. You'll need a table to cut on and a Craftright 300mm 2 Piece Quick Action Clamp to hold the timber in place. My best advice is to double check your measurements, mark all the timber with a cutting line and cut them slowly one at a time. Because you don't forsee any other future projects coming along these basic tools will get you going.
Let me call on our experienced members @Dave-1, @Nailbag and @AlanM52 for their recommendations
Please remember to wear personal protection such as gloves, goggles and a mask.
AlanM52
Hi @alibee,
Follow @EricL's sawing recommendations and will add 'Let the saw do the work'.
You did not ask about installing the shelves but for that particular job I will mention my preferred method because it links back to you concern about a snug fit - use shelf supports AKA shelf pins. To reduce effort and errors only layout and mark the two pin hole locations on one side, then transfer all that in one action over to the other side using something from the kitchen - greaseproof paper.
When you cut the shelf slightly favor the inside of the marked cut line so when you pop the shelf in and let it drop on the self pins there will be a small amount of play - that's OK. That method should also cover you for any top to bottom width variations.
Noyade
If a handsaw is the way for you - there may be slight dimensional inaccuracies with the fit - so I was thinking of longer 'forgiving' brackets for support.
https://www.bunnings.com.au/hafele-23-x-23mm-angle-bracket-20-pack_p0037959
Just a thought.
Cheers @alibee
Afternoon @alibee
A handsaw works well but it can be hard going and keeping the cut straight if you are not use to it (my cuts still tend to curve :surprised: ) I did see an ozito battery circular saw for $88 skin only today (batteries are seperate) at bunnings :smile: They will make nice cuts and you could also cut smaller strips to screw to the sides of teh existing builting so the new shelf rests on them. Its more permanant yes but would be solid and a little more forgiving then the pin supports.
alibee
Thanks @AlanM52. These are great tips! Thank you so much. I've tried all sorts of ways to mark the pin holes before (none of them very successful) but never even thought of greaseproof paper. Thank you. The tip re favouring the inside the cut line is also really helpful. I'm never really sure which side to favour and end up doing a bit of both which does not lead to a very straight line.
Thanks for sharing your wisdom.
alibee
Thank you so much @EricL I appreciate all the links to what I need. That's really helpful. Thanks for the reminder to wear goggles, mask and gloves. Can I please ask what kind of gloves I would need? I've not come across the idea of gloves for this kind of job before. Can I also ask if I need a special type of mask or is a standard N95 ok?
Thanks for the recommendation for the handsaw. I have quite a few shelves to cut and a bit of a dodgy shoulder and so I'm not sure how I will go with a handsaw. I would like to consider getting a power saw of some sort. My brother recommended a jigsaw but would a circular saw be easier to use for this kind of project? I intend to watch lots of youtube videos so I know how to use if safely.
Thank you so much for your help.
alibee
Thanks @Noyade I'd never thought of using brackets. I'll look into that. Much appreciated.
alibee
Thanks so much for the recommendation @Dave-1 I had thought about a circular saw but they look quite intimidating. Are they easier to use than a jigsaw? I like the idea of the smaller strips for the linen press as that is what is already in there. I hadn't even thought about the fact I could make DIY those as well. Thanks for the tip.
Hi @alibee,
These Mechanix Wear Eco Speedknit Gloves or Trojan Cut Resistant Safety Gloves would be suitable. They are just there to protect against cuts from the sharp edges of laminate and things like splinters. They are handy for a variety of tasks, so it is worth having a pair around.
A standard N95 mask would be fine for this project.
Circular saws are much better for long straight cuts, whereas jigsaws are better if you are doing more intricate work where curves and cutouts need to be added. The best option depends on the circumstance, but generally, if you are doing straight cuts, a circular saw is better; if you are doing curved cuts, a jigsaw is better.
If you have any further questions, please don't hesitate to ask.
