How to install floating floor over existing timber?
SMGrays
Hi, I am looking at installing engineered timber floating floor boards over existing timber floor. The floor is pretty level throughout with different timber boards used in separate parts of the house. Will I be able to lay directly to the existing floor or should I put an MDF or ply board down first? I have a 3mm acoustic underlay and the floating floor planks are 12mm. I have already installed the new floor in a bedroom as you can see there is already a small height difference so I am concious of adding to much height.
Re: Floating floor over existing timber floor
Hello @SMGrays
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your timber floor.
Installing engineered timber floating floorboards over an existing timber floor is generally feasible, especially if the subfloor is level and in good condition, as you've described. Since you've already laid the new flooring in one bedroom and observed a small height difference, it's understandable that you're concerned about adding more thickness.
If your existing timber floor is mostly level, sound, and free of squeaks or movement, you can likely install the floating floor directly over it using your 3mm acoustic underlay. This approach minimizes added height and avoids the complexity and cost of additional layers. Before laying the underlay and floorboards, make sure the existing boards are securely fixed by screwing down any loose ones, and that the surface is clean, dry, and relatively flat. Minor imperfections can be absorbed by the underlay, but significant dips or bumps may need sanding or levelling compound.
Adding a plywood or MDF layer is typically recommended when the subfloor is very uneven, unstable, or made of varying materials and thicknesses. This creates a uniform surface, but also adds 6–9mm of extra height, which could further complicate transitions to other rooms or affect door clearances. Given your concerns about height, it would be best to avoid this unless your current floor has problem areas that would cause long-term issues for the floating floor.
Your 3mm acoustic underlay should offer a good balance between sound insulation and minimal added height. Keep in mind that transitions between rooms can be smoothed with reducer profiles or threshold strips, and doors may need trimming to accommodate the new floor height.
In your case, proceeding without the extra plywood or MDF layer seems reasonable, as long as the existing timber is stable and flat. Just be diligent about preparing the surface beforehand, and you should be able to achieve a smooth, durable result without introducing excessive height.
SMGrays
Thanks for the advice and reassurance. I was going back n forth with each method. I have rechecked the subfloor and happy with the leveling and stability. Just a few planks I need to fix up but I'll look to get started.
Hi @SMGrays
Please keep us updated with your progress, we look forward to seeing your flooring fully installed and ready for use.
