How to tile over concrete slab?
FEH
Whats the best tile adhesive for laying 200x300mm pressed ceramic tiles on a concrete slab please? There is so much choice I am overwhelmed! The slab has been down for 9 months. I'm aiming for a 3mm bed. Not a wet area.
Also, do I need to prep the slab first?
Thanks for your suggestions!
Re: Tiling onto concrete slab
Welcome to the Bunnings Workshop community @FEH. It's brilliant to have you join us, and many thanks for your question about tile adhesives.
For 200 × 300 mm pressed ceramic tiles onto an existing concrete slab, Davco 20 kg Ultraflex Ceramic Tile Adhesive is a very suitable choice. It’s designed for ceramic tiles on concrete.
In terms of preparation, yes, you do need to prep the slab first. Make sure the concrete surface is clean, dry, free of dust, grease and loose material. Any cracks or hollows should be filled and smoothed first (you can use a concrete patch or levelling compound). If the slab is very smooth or has a light laitance on the surface, getting it slightly keyed with a light sanding or broom finish helps the adhesive bond better.
Once the surface is prepped, you can mix the Ultraflex adhesive to the manufacturer’s instructions and apply it with a 6 mm notch trowel, pressing the tiles firmly into place, which will bed them down to around 3mm. After installation and once the adhesive has set, grout and then seal if needed for your tile type.
