Does Bunnings cut wood to size?
Many Bunnings stores offer a timber cutting service to help you get your wood home and get started on your project.
Here are some frequently asked questions about our timber cutting service to help Bunnings Workshop members.
What type of cuts can be done at a Bunnings store?
Bunnings stores typically have two types of saws for timber cutting.
  • Panel saw – used to cut large sheet materials into smaller rectangular sections and pieces. The machine is capable of both horizontal and vertical cuts on most of our board products. Some examples of products that can be cut using a panel saw include Melamine and Plywood.
What size cuts can be made and how much does it cost?
Cuts to timber and panels boards are rounded up to 100mm increments. We are unable to do precision cuts. The minimum length of cut timber is 600mm.
Customers are required to purchase any remaining offcuts measuring less than 1800mm.
Multiple timber cuts may incur a charge of $1 per cut.
Is this service available at my local Bunnings?
You can check whether the timber cutting service is available at a nearby store by visiting the Bunnings website. Here’s how:
  • Mobile device - Select your nearest store and then click on your store's name on the top left of the screen. This will take you to your store's information page, including details about what services they offer
  • Desktop computer - Type the nearest store's name in the change store drop-down and then click on store details. This will take you to your store's information page, including details on what services they offer.
Can I bring my own piece of timber to be cut?
Due to the many variables associated with timber products, we can only cut products purchased from our stores.
When is the best time to visit a store for timber cutting?
Visiting at a quieter time will ensure faster service. It's best to avoid weekends and public holidays as many other D.I.Y. enthusiasts will also be looking to build their own projects.
What if I want to do the cutting at home?
Knowing what saw to use and how to use it is the key to success. Here are some useful guides to get you started:
What if I can't get my timber home?
We offer a number of options to get your products home safely. You can use our free courtesy trailer for up to two hours. If you need more time you can also hire a trailer, a ute or a van to suit your needs. We also offer a comprehensive delivery service to assist you in getting your purchases home. Most stores offer same day or next day service. Please contact your nearest store for details.
As always, our helpful members are ready to assist with any questions you have on completing precision cuts for your D.I.Y. projects at home.
Please feel free to let me know if you have further questions about our helpful timber cutting service.
kirangill
How to cut a kitchen melamine reversible benchtop?
Can bunnings cut to the required size, as its too big for the space.
Re: kitchen melamine reversible bench top
Hello @kirangill
I'm sorry but the shop saws are not able to cut benchtops as the blades are too rough and will chip the surface of the benchtop. Plus, they are not designed for precision cuts. My best advice is to take into consideration the possibility of cutting your own benchtop by investing in an Ozito PXC 18V 165mm Circular Saw. A very sound investment when doing D.I.Y. projects. I also suggest looking at this guide - How to choose the right power saw for the job by @Adam_W
NathanG
Re: Does Bunnings cut wood to size?
Hi, just asking can Bunnings help me cut this product? https://www.bunnings.com.au/2440-x-1220mm-3mm-plywood-pine-premium-bc-grade_p0340267
It is a 2440X1220X3mm pine plywood.
Hello @NathanG
I'm afraid the panel can't be cut by the shop saws due to its thickness. If it were like 16mm or 18mm the panels strength would be able to put up with the saws power.
But because the panel is not that thick, you should be able cut yourself, I propose looking at investing in either a hand saw or an Ozito PXC 18V 165mm Circular Saw. I also suggest having a look at this guide - How to choose the right power saw for the right job by @Adam_W
kraanti
I currently own a few mdf shelves from an old project. Can Bunnings cut them to size for me?
Re: I currently own a few mdf shelves from an old project. Can Bunnings cut them to size for me?
Welcome to the Bunnings Workshop community @kraanti. It's fabulous to have you join us, and many thanks for your question about our cutting service.
I'm really sorry, but we’re only able to cut timber boards that are purchased in-store at Bunnings. Unfortunately, we can’t cut previously owned or brought-in materials like MDF from other projects.
If you'd still like to repurpose your shelves, we’d be more than happy to help you choose the right tools for the job. A jigsaw or circular saw can be a great option for cutting MDF at home—just make sure to wear a dust mask, as MDF can produce fine dust when cut. Let us know if you’d like help picking out the right gear.
Thank you Mitchell, I’ve found a way to cut them at a Makersspace.
Im also building a bookshelf and I was wondering if Bunnings could cut the Timber panels I buy in store for my shelves?
Im also wanting to add timber fence to my wall for another DIY project but I want to cut some parts so I can use my plug points. Can Bunnings cut that too? Or can you advise what would be the best way to cut them?
Hi @kraanti
We do cut a variety of timber panels in-store. For specific details on whether our team can perform the cuts you need, it's best to speak with the team member in the timber yard at your local store.
HG
Small wood Cut to size
Can Bunnings cut wood to the following size?
  • If so, how much does it cost?(size in mm) I will need 4 in total
  • Can all Bunnings stores provide this service?
  • Do I need to make a booking for the cut?
  • Should I upload or bring a picture to show the staff?
  • Once I arrive at Bunnings, where can I find the right person to help with this?
woodwood
Re: Small wood Cut to size
Welcome to the Bunnings Workshop community @HG. It's wonderful to have you join us, and many thanks for your question about our cutting service.
While Bunnings does offer a cut-to-measure service for timber, it’s important to note that this service is intended to help customers get their timber home more easily—it’s not a precision cutting service. If you're needing exact measurements or any custom work such as rebates or grooves (like the 18mm rebate you mentioned), that would require specialised equipment such as a router, which can't be done on the in-store saw.
For a job like this, you'd really need to engage a cabinet maker or someone who offers professional woodwork services. A local Men's Shed might also be a great option—they often take on small projects like this and may be happy to help.
If you do need standard cuts to help get your timber home, you can speak to the team in the timber section of the store—no booking is required, and there may be a small fee after the first few cuts. Bringing a photo and clearly written measurements is always helpful to explain what you’re after.
