I found this hallway table on marketplace for free and decided to give it a complete makeover.
Dewalt orbital sander
cordless drill
wagner flexio 690 spray gun
dulux aqua enamel water based paint
british paints 4 in 1 primer
brushed bronze knobs
peelable wallpaper
stencil
wooden appliqué beads
Cabot’s water based polyurethane matte
wood glue
poly paint stripper
builders bog
wood filler
Wagner flexio 690 spray gun
dewalt orbital sander
cordless drill
stanley knife
Applied paint stripper to the top and scraped off the old varnish.
used my sander to remove old stain and get the top smooth starting with 80 grit up to 180 grit.
scuff sanded the entire piece.
used builders bog to fix any obvious signs of damage or wear and tear.
sanded the bog smooth.
taped off the top and sprayed 2 coats of primer to the legs and body of the table.
sprayed 4 coats of dulux aqua enamel paint to the legs and body of the table.
sprayed the drawers.
added a stencil to the side of the drawers.
glued the wooden beads to the front of the drawers.
added wallpaper to the inside of the drawers.
whitewashed the top of the hallway table.
sealed the top of the table with 3 coats of Cabot’s polyurethane.
added gold knobs to the drawers.
Hi @alanasfurniture,
What an incredible transformation — you've done an amazing job breathing new life into that hallway table! The attention to detail with the stencilling and wallpaper-lined drawers really takes it to the next level. It’s inspiring to see how a bit of creativity and the right tools can turn a free find into something truly stunning.
Thanks so much for sharing your project with the community!
Thank you so much, I usually flip pieces to sell on marketplace but this one was a true beauty which ended up staying in my own home to love forever.
