Your best painting tips
Painting can be a fantastic low-cost way to freshen up a room and add value to a property. For a small investment, the right paint job can make a big impact.
Painting is also something that anyone can do. But I'm sure the Workshop community has plenty of great tips for getting the best result possible.
Please share your painting tips in the discussion below.
Re: Share your best painting tips
Anyone planning to get stuck into some painting over the Easter break?
There's some good painting tips in this article - https://www.domain.com.au/advice/get-grip-discover-best-paintbrush-job
I can especially relate to the one about investing in quality brushes. I don't understand why people spend heaps of money on paint but then use cheap brushes and don't get a good finish.
Prof
Becoming a Leader
Also if you put your wiped brush in a freezer bag and wrap it very tightly and then put it in the fridge, it will keep like that for weeks..
Prof
Becoming a Leader
That's a good tip Marley..I'll do that next time..
CathD
Making a Splash
Some good tips here for painting ceilings - http://www.handyman.net.au/10-tips-painting-ceilings
SammyE
Cultivating a Following
Thanks a lot for the tips here. We've just started painting and I can definitely agree with the quality of the accessories. First we thought the paint wasn't good as we went for British Paint and not Dulux. Then we upgraded our roller and it worked like a charm! It really made a difference.
Also learnt the tip on wrapping the roller in a plastic bag instead of washing, which did save time and water. It was so convenient!
Btw, can someone tell me what we can do about sliding doors and windows with metal frames? They don't seem like we can paint them all over. We have all frames in beige and we'd like to have them in white. Tnx!
Good stuff @SammyE, glad to see that some of the tips were helpful to you.
You might also like to check out these discussions regarding painting alumnium doors and windows:
Hope that helps. It would be great if you could share some before and after photos - it's certainly a common project.
SammyE
Thanks for the tips Jason. Sure will do,
Visitors to this popular discussion might like to check out this - Preventing paint bleed while using masking tape
There's a great tip from some videos shared by @Brad about using chaulk to help ensure sharp lines with no bleeding.
melheasman
Re: Your best painting tips
Jason,
Do you happen to know the name of the paint used in the above picture?
