How to ensure window ventilation in bathroom renovation?
Ben2065
Cultivating a Following
Hi everyone,
I am slowly restoring my heritage home (built aprox 1890's) I am currently trying to divide my original double hung window (no sash cord/pulley etc ever installed but slides very well). I need to divide the rooms along the blue line to allow a toilet room with small hand basin on the right (hot water service to be relocated) and a separate room on the left which won't be used for shower or as a wet room. I do not wish to interfere with the sewer plumbing for the toilet and therefore need to divide the window. After countless hours pondering what to do I have come up with a few options.
Option 1
Leave upper and lower window panes in their closed position and install window mounted exhaust fans either side in the upper window pane. I would install a timber fake mullion down the midline with foam seal against the window to allow the stud to marry up to this. I am concerned the noise this would cause on a daily basis.
Option 2
Leave the upper window in the fully closed up position and raise the lower window enough to install an opening floor vent (similar to this https://www.bunnings.com.au/accord-10-x-30cm-antique-brass-marquis-floor-register_p0810309 ) mounted in marine ply to seal the opening around the vent. This way I can open the vent to allow air flow and can close the vent to prevent airflow if cold/wet weather (this window is rarely exposed to direct rain or heavy weather) I am not familiar with these vents and if their closed position provides adequate air seal. Obviously it would be possible to attach insect screen material on the outside of this vent to avoid insects entering.
Option 3
Install an centre mullion and 2 casement windows which open into each room due to bars outside the window preventing outward opening. Whilst more ideal I can see this being a far more complex and labour intensive process
Option 4
Retrofit the window with a centre mullion and custom make double hung windows both sides with salvaged old timber windows. I am confident this would look nice however would likely be an extremely challenging and demanding process
I have considered retrofitting louvre glass windows either side however when this was quoted it is cost prohibitive (aprox $1300 supply only)
I would be doing the work myself and am confident with the timberwork and have fully restored the all the old timber double hung windows in my place. The image attached is an older image in my renos and shows the original arrangement of the window with the upper pane lowered to its resting position with insect screen material stapled in position.
I look forward to your suggestions/thoughts
Re: How to ensure window ventilation in bathroom renovation?
90mm studs would indeed be typically used for creating partition walls @Ben2065.
Ben2065
Hi @MitchellMc @EricL  @Dave-1  @Jason
I have done many plans, sketches and thought bubbles over this issue. I plan to keep it simple and install 2 tall narrow fixed timber windows with exhaust fan mounted at the top. I have found some old timber cedar windows which are only 4cm too short so I can bulk them out with some cedar I have at home. The windows are too wide but I can take one side off each window and bring them down in size and reattach the corners with mortice and tenon joints and have the glass cut to their new size. The main question I have now is am I best to use cedar, oregon or any other timber choice for the centre post (mullion) between the windows? The timber will be painted so will be protected and the eaves provide significant weather protection too.
Glad to hear you've found a solution @Ben2065. As we don't sell Cedar and Oregon, I'm not particularly familiar with their longevity. We do have H3-treated Pine, which when painted and sealed, will last for an exceptionally long time exposed to the weather.
Ben2065
Hi @MitchellMc
Which would you suggest would be more suitable?
https://www.bunnings.com.au/112-x-112mm-2-4m-post-h3-treated-pine-laminated-losp-fj-2-4m_p84012874
https://www.bunnings.com.au/150-x-100mm-3-0m-sleeper-h4-treated-pine-wet_p8500184
https://www.bunnings.com.au/140-x-45mm-outdoor-framing-h3-treated-pine-2-4m_p8032264
(Would be using a few of these screwed/sandwiched together to give aprox 140x90)
Not sure if the LOSP post would be more resistant to warping/cracking than the sleeper or outdoor framing. The middle post of the window frame is not taking load but is more to seal the middle of the window. Obviously the LOSP post is greater cost but trying to determine if it would be more suitable for the application. Many thanks for your assistance.
Hi @Ben2065,
I'd recommend the 112 x 112mm 2.4m post h3-treated pine laminated losp fj as it's much more stable and less prone to warping. It's also been milled to a smooth finish, so it has a much nicer appearance.
Ben2065
Thank you @MitchellMc
As space is very tight either side of the stud wall (blue line) and I am trying to avoid redoing the existing plumbing, would 70mm studs be acceptable? As mentioned previously I am considering installing a false ceiling for the toilet room at the height of the existing cornice (aprox 2.4m) as the top of the existing cathedral ceiling is aprox 3-3.5m high so it doesn't feel too much like a mine shaft. The toilet room will be aprox 1.35m x 1.35m with a stud wall in the position of the blue line. Finally whilst there is only a toilet and handbasin in the room I suspect that villaboard will be a more suitable stud wall cladding material than gyprock or aquacheck. I plan on simply painting the walls of the toilet room and placing vinyl flooring down. Many thanks for your assistance.
Hi @Ben2065,
"Would 70mm studs be acceptable?" That's a question best left to an engineer. I'm unsure if the construction code stipulates that an internal non-loadbearing wall needs to be constructed with 90mm studs. 70mm studs are seen quite commonly in areas with no more than 2700mm high walls. The reason we use 90mm studs is for their additional structural nature, and if they need to be notched to run utilities there is plenty of room in their thickness for that. If you were to notch a 70mm stud, there wouldn't be much left of it.
Villaboard can be used if you want to retain the 4mm difference between it (6mm) and plasterboard (10mm). However, plasterboard typically allows a higher level of finish.
Ben2065
Hi @MitchellMc
I understand that 90X45 would be ideal. I am still considering 70mm framing as all the existing framing is 70X45 oregon installed prior to my ownership. I am obviously reluctant to pull out the old oregon framing! I have attached a sketch of my plan to modify the window. Does this look a reasonable plan? Obviously the multiple planks of 140X45 H3 pine would be fixed together with screws to hold them as a compact laminated but not glued post. The post would be screwed into the window frame. Unfortunately my computer skills are not as good as my carpentry skills and the 4 planks of 140X45 H3 are all the same size but in the drawing they are not to scale on thickness. I welcome your advice/suggestions. I assume blue board for the exterior cladding on the left side of the window would have much greater life than say marine plywood.Window Modification Plan for toilet room.jpg
Hi @Ben2065,
I'm not entirely sure I understand the section with the 140 x 45mm timber. I presume that it's stood on its end. I'm not a carpenter, but I would continue the new wall frame through the window to the point of the external blueboard.
Always use blueboard, as marine ply is not a suitable external cladding.
It sounds like you are planning on framing the left-hand side of the window. If so, I've spent some time putting a plan together. Here are some renderings for you.
Ben2065
Thanks so much to you all for your extensive advise and discussion. After significant and serious deliberation I have changed the plan to retain the window intact and move the stud wall to the right. Hot water heater is disconnected and empty/out of the way and old toilet is mocked up in position. I plan the install a stud wall to close the current doorway (red lines in original image) (I already removed the jam) as well as a stud wall the divide the two rooms (green lines in original image). I will be using 70X45 framing as well as using villaboard (blue fibercement sheet) for all 4 walls. I was advised to use H3 framing timber incase of moisture issues from the toilet room however I am considering if H3 70X45 is more risky to twist and warp? Would you advise H2 or H3? I will be using sheet vinyl for the toilet room floor and will not be waterproofing the room. Walls and false ceiling for toilet room will be painted. Many thanks for your assistance.Old toilet mocked up in position with position of dividing wall laid outOld toilet mocked up in position with position of dividing wall laid outPlanned side entrance door to toilet roomPlanned side entrance door to toilet roomPlanned T junction of stud walls with longer packer pieces of coursePlanned T junction of stud walls with longer packer pieces of coursePlanned T junction of stud walls viewed from inside toilet room showing landing area for wall claddingPlanned T junction of stud walls viewed from inside toilet room showing landing area for wall cladding
